Estimating The Size Of A Single Molecule Of Oil Using Water
An excerpt from Lord Rayleigh’s published manuscript.
What is the size of a single molecule of oil? What may initially seem like a trick question – answerable only through the use of complicated, high-tech scientific equipment – is actually as easy to calculate as the circumference of planet Earth. Much like how [Eratosthenes] used a couple of sticks to achieve the latter feat back in about 240 BCE, the size of a molecule of olive oil was calculated in 1890 by [Lord Rayleigh], which is the formal title of [John William Strutt]. Using nothing but water and said olive oil, he managed to calculate the size of a single olive oil molecule as being 1.63 nanometers in length.
To achieve this feat, he took 0.81 mg of olive oil and put it on a known area of water. Following the assumption that the distributed oil across the water surface would form a monolayer, i.e. a layer of oil one molecule thick, he divided the volume of the oil by the covered area, which gave him the thickness of the oil layer. Consequently, this result would also be the dimension (diameter) of a single olive oil molecule.
Many years later we know now that olive oil is composed of triacylglycerols, with a diameter of 1.67 nm, or only about 2% off from the 1890 estimate. All of which reinforces once more just how much science one can do with only the most basic of tools, simply through logical deduction.
21 thoughts on “Estimating The Size Of A Single Molecule Of Oil Using Water
    1. I can’t find the text right now, but the PSSC Physics lab went something like this:
      Prepare a large pan of water, allow to settle.
      Sprinkle chalk dust lightly on the water surface.
      Dilute a small quantity of oil accurately in a large quantity of alcohol, 100:1 or so.
      Measure the volume of a single eyedropper drop of the solution (drip 100 drops into a graduated cylinder), and calculate how much oil is in a single drop.
      Drop one drop of alcohol-oil on the water and wait for it to settle: the floating oil solution spreads away the chalk dust, and the alcohol evaporates, leaving a one-molecule thick disk of oil, demarcated by the dust edge.
      Measure the diameter, and from the known volume of oil present, calculate the thickness of the disk.
      Assume it’s a monolayer, and boom: there’s your molecule size (or at least one dimension of it)
      1. In fairness, olive oil contains multiple different fatty acid triglycerides, as well as other molecules, so you can’t really say that a single molecule is, itself, olive oil. I suppose you can argue that this calculates an average size, but then that ignores sterols and other things which are in there too.
        Still a fun exercise though.
          1. I leave proving non-existence of widgets for the experts.
            Fair doesn’t enter into it. It is correct to say that no molecule of olive oil exists because there is no such thing. Sheldon out.
  1. it seems like a big step from experimentally determining a minimum thickness of oil to asserting you know the shape or orientation or layering of the molecules that compose it.
    you can do a lot easily with simple methods but the hard parts are still hard even if you can come up with a simple experiment in the end.
  2. A lot of whinging when this is good applied mathmatics and if it was necessary to determine the thickness of a molecule you’d have it to a good enough approximation for whatever practical purpose you’d put the number to.
  3. I fondly remember this experiment from 1970 science class. Lord Rayleigh got a better value but there is nothing like hands-on experiments.
    Same class, same instructor, had a tape recoding from one of the Apollo landings in which there was an “echo” in the voice recordings. By measuring the lag and starting with an estimate of the earth-moon distance, we calculated the speed of light.
    Fun times.
  4. We did this experiment in school; or tried to. What actually happened was that when we had our spread-out droplet and were prepared to measure it, Neil Roberts came along with a ruler, held it threateningly just above our basin, and said loudly “Wouldn’t it be a shame if I stirred the water?” A struggle ensued, which resulted in the ruler going into the water, the experiment being ruined, a wet mess, and Neil protesting that he wasn’t really going to stir our experiment. So I didn’t discover the size of a molecule of oil, but I got a funny memory which is much more valuable.
  5. Wow. It really spreads out down to a single molecule? But we can still see it? Cool.
    I guess I can picture why it would, so long as there isn’t enough oil to completely fill the surface area of the container. But I wouldn’t have assumed that there wouldn’t be any molecules stuck to one another vertically or some other random stuff making it more than one molecule thick.
    Learn something new every day
  6. Oh.. And this sounds a h377 of a lot easier than what Eratosthenes did. How do you determine the exact time of day to that level of accuracy to take your measurements in two different cities on two different days with the technology of the time? I mean.. a decent rough estimate sure but he was a lot closer than that!
Leave a Reply to I Alone Possess the TruthCancel reply
