Very Tiny Cube Has 384 RGB LEDs
When it comes to making things that glow, there are two ways to stand out from the crowd. You can make something very big, or something very small. [DIY GUY Chris] has done the latter, producing a tiny LED cube that he says is the world’s smallest.
As is so often the way, the build relies on tiny WS2812B-compatible LEDs in a 1 mm x 1 mm form factor. They’re mounted on a series of teeny interlocking PCBs that come together to build a cube that’s just 8 cubic centimeters in volume. Power is courtesy of a small lithium-ion cell that lives inside the cube. Data and power signals flow around the cube via solder connections along the edges of the faces of the cube.  Running the show is an ATmega328P, the same microcontroller you’d find in an Arduino Uno. It’s responsible for sending out commands to the LEDs to create various animations.
We can’t speak to [Chris’s] claim about being the world’s smallest, but it is small. We’ve seen other builds in a similar vein, like this barely-larger D20 with a full 2400 LEDs, though. Video after the break.
2 thoughts on “Very Tiny Cube Has 384 RGB LEDs
  1. Very nice! Just a minor drawback: without diffuser, you can clearly see light position shifting in every single led for pure R G or B color, which i find a little annoying.
  2. I’ve used these leds to make a christmas decoration, 300 pcs to be precise. They are insanely bright for the size and look absolutely magic when you put lots of them together (in a line in my case). Really nice
Leave a Reply to GéraldCancel reply
