Mini Robotic Arm Lets You Start Your Own Mini Assembly Line
A black and white robot arm is held in a human hand against a grey background. Next to it, in white lettering, is the Arduino logo and the text, "Mini Robotic Arm."
Automating tasks with a robot sounds appealing, but not everyone has the budget for an Aismo or Kuka. [FABRI Creator] has a great tutorial on how to build your own mini robotic arm for small, repeatable tasks.
Walking us through the entire build, step-by-step, [FABRI Creator] shows us how to populate the custom-designed PCB and where to put every servo motor and potentiometer to bring the creation to life. This seems like a great project to start with if you haven’t branched out into motion systems before since it’s a useful build without anything too complicated to trip up the beginner.
Beyond the usual ability to use the arm to perform tasks, this particular device uses an Arduino Nano to allow you to record a set of positions as you move the arm and to replay it over and over. The video shows the arm putting rings on a stand, but we can think of all kinds of small tasks that it could accomplish for us, letting us get back to writing or hacking.
If controlling a robot arm with potentiometers sounds familiar, maybe you remember this robot arm with an arm-shaped controller.
25 thoughts on “Mini Robotic Arm Lets You Start Your Own Mini Assembly Line
  1. When was a kid decades ago radio shack I believe it was had a robot arm toy you controlled with a couple of joysticks. I ALWAYS wanted one of those then like 30 years later I found a perfectly working one at a garage sale and it was every bit as amazing as I’d remembered.
    This thing looks like an even cooler version of that and if you can actually program it to do stuff for you that is even more awesome. Super cool build! Thanks!
  2. I use this one in my assembly line:
    https://www.hiwonder.com/products/maxarm?variant=40008714092631&srsltid=AfmBOoq7MAocxCJW6Ioi1sXCvoOAIS9BgKzRSACjF1T6ak6H4hokkgTU
    I only paid $159 on Amazon, had to build a better suction cup, and connect a wire to the button that starts the procedure. You program the routine, and save it to the robot under a certain name and the button starts the routine. Supports inverse kinematics so you can program trajectories in Python, but I just need 2 routines for separate tasks so I took the lazy route and just wired in the button.
  3. This robotic arm, and the others that are similarily built all use open loop controllers don’t they? I would be honestly tempted to get one if it had an encoder. I wonder when that will become standard?
    1. Depends if you consider that the servo’s potentiometer is an encoder. A servomotor is closed loop since it knows where it is. But those cheap arms use cheap servo and the precision is very low, hence low repeatability since errors accumulates for each joint.
    1. It’s more that the business culture just doesn’t understand sharing information because there are no regulations for things like that in China and IP law there is just “whoever has better connections gets to claim they own it”. This means that software and design are treated as trade secrets even if a company didn’t develop them.
      For an example, most development trees are tarballs of the entire regard code base moved between developers even if they can directly download an updated version and only copy their drivers or whatever special sauce. This is why you can get brand new Android devices running kernel 2.4.
Leave a Reply to Eric MocklerCancel reply
