Enhiker Helps You Decide If Its A Good Day To Hike
Many of us check the weather before heading out for the day — we want to know if we’re dressed (or equipped) properly to handle what Mother Nature has planned for us. This is even more important if you’re going out hiking, because you’re going to be out in a more rugged environment. To aid in this regard, [Mukesh Sankhla] built a tool called Enhiker.
The concept is simple; it’s intended to tell you everything you need to know about current and pending conditions before heading out on a hike. It’s based around Unihiker, a single-board computer which also conveniently features a 2.8-inch touch screen. It’s a quad-core ARM device that runs Debian and has WiFi and Bluetooth built in, too. The device is able to query its GPS/GNSS receiver for location information, and then uses this to get accurate weather data online from OpenWeatherMap. It makes some basic analysis, too. For example, it can tell you if it’s a good time to go out, or if there’s a storm likely rolling in, or if the conditions are hot enough to make heat stroke a concern.
It’s a nifty little gadget, and it’s neat to have all the relevant information displayed on one compact device. We’d love to see it upgraded further with cellular connectivity in addition to WiFi; this would make it more capable when out and about.
We’ve seen some other neat hiking hacks before, too, like this antenna built with a hiking pole. Meanwhile, if you’ve got your own neat hacks for when you’re out on the trail, don’t hesitate to let us know!
10 thoughts on “Enhiker Helps You Decide If Its A Good Day To Hike
  1. The case is nice and documentation looks ok. It’s a bit unfortunate that this project is a solution looking for a problem.
    The device has gps and is has enough processing power. Off-line map navigation might be a more suitable application.
  2. the article seems to have missed one of the main focuses of this device, which is to do ongoing weather monitoring, forecasting, and logging of environmental data using a suite of onboard sensors without internet access. Not to mention it also keeps a GPS track of your journey and functions as an emergency power bank. it’s not just loading forecasts from the internet.
    (and alas, but perhaps unsurprisingly, most of the critiques in other comments are from people who didn’t realize this either)
    that said, one could certainly still debate whether it’s a sensible, practical device, and whether or not it could’ve been implemented on much simpler and cheaper hardware…
Leave a Reply to S OCancel reply
