Creating A Signature Wood Joint
A pair of hands hold two dark brown boards perpendicular two each other on a light brown benchtop. There are two light brown oval dowels in the end of one board that then project toward holes in the opposite board. Circular holes in the oval dowels are visible perpendicular to the second board, and will match up with holes in the board once pressed in. A cylindrical dowel is laying next to the joint and will be placed into the circular holes once assembled.
We really love when makers make their construction techniques evident in an aesthetically-pleasing way, and [Laura Kampf] has created a clever joint that reveals how a piece is made.
[Kampf] is a big fan of using her domino joiner, which is similar to biscuits or dowel joinery, but she didn’t love how it hid the construction of the joint. She first figured out an “off label” use of the joiner by running it from the outside of the joint to show the exposed domino from one end.
Building on the concept to show an interesting contrast on both sides of the joint, she drilled a hole perpendicular the domino and placed a dowel through it, creating a locking joint. The choice looks great once a finish is applied to really accentuate the contrast, and another bonus is that if glue is only applied to the dowel and domino, it becomes trivial to separate the joint if needed by drilling out the dowel.
If you’d like to see some other interesting ways to join wood, how about this laser-cut wedge tenon, soda bottle heat shrink, or this collection of CNC joints.
25 thoughts on “Creating A Signature Wood Joint
  1. Neat. Also what if she replaced the smaller dowel with a brass nut and screw? That way you can disassemble and reassemble without having to drill out the dowel. Nice to see a woman carpenter too, good to see see women in carpentry.
    1. For some reason I find that wood and computers don’t go together very well. The wood parts end up looking somehow clumsy and out of place – or if you try to hide the computery parts, then it becomes a weird rectangular lump of wood with wires sticking out of the back.
      You can have wooden details on a computer and that works fine – but if the majority of it is made out of wood, then it starts looking kinda dumb.
  2. “Why is nobody using this technique?”
    Because it’s extra work, and the whole point of the domino is to provide a hidden, reinforced joint.
    But, I suppose you have to keep coming up with new material for videos. Gotta get those clicks!
    1. There’s also very little to keep the drilled out domino from simply splitting along the grain, especially if you try to do the old offset hole trick to actually pull the joint in tight with the dowel. You can easily just rip off the tiny bridge at the end of the domino.
      Most novelty joinery like this ends up compromising the structure, not making it better – but it looks cool.
      And because the video author invented it herself and has dubbed it her new “signature wood joint”.
      I guess asking “Has anyone seen this style of wood joint before?” would have been better, but is not nearly as clickbaity.
  3. If you want to learn how to make a classic mortice and tenon joint with nothing but your hands and basic woodworking tools, I can think of no better than a lesson from Paul Sellers: https://www.youtube.com/watch?v=aBodzmUGtdw
    It’s an 30 minute unabridged video where he calmly makes a joint and tells you all about it. He’s offloading decades of experience into your brain. Then go and try it yourself. You’ll transcend into new levels of being.
    1. Thanks for that! Carpenter in training here. I just spent 12 hours over the last weeks just making dovetail joints on the four corners of one drawer. It takes a lot of time, but is extremely rewarding. Doesn’t make great youtube though, and would not do it for a living.
  4. A domino joint is technically a “loose tenon joint” – it’s just a brand name for a particular system of making them.
    So this would be a “half doweled loose tenon joint”, or a “half locking loose tenon joint” if you wish.
  5. Won’t watch video but will comment anyway because reasons.
    Wood joints are like a 1000+ year established technology. Maybe it was Cambridge that planted oaks so that when roof failed 400 years later they would have wood to replace it.
    Not saying it is impossible to do something better with the material but it would be far uncommon. Especially considering the expected lifetime of a well made joint is generations. Not lifetime of YouTube likes. Different goals I suppose.
    Cheers
      1. Well, to be clear, loose tenon technology is nothing like new; it was used, for instance, in Greek and Roman ships.
        The particular machine, called a Domino, is only a couple of decades old.
        It’s a bit like a fat dowel joint, but with somewhat better long-grain gluing surfaces.
    1. Yes, believe that was one of the Cambridge colleges. Apparently people still kicked up a fuss about chopping down the oaks despite them being explicitly planted for that purpose, and replaced with new oaks for when it next needed doing. Planning on that timescale is incomprehensible to most people.
  6. Japanese joinery & carpentery is without glue, nails, screws, only wood. 3 or 4 generations old furniture is well kept and passed on to the next generation.
    For who does not now, there are 4 branches of Japanese carpentry, each one with their own tehniques: furniture, panels (for doors and windows and alike), house building, temple building (the last two are very close). As the subject of the craft gets bigger, you can see the techinique shifting to acomplish the required task. For instance, how to make a long beam, using two smaller trunks as shorter beams. No glue, no nails, no screws.
Leave a Reply to HirudineaCancel reply
