All Aboard The Hack Train: Nottingham’s LED Revival
Nottingham Railway departure board in Hackspace
Hackerspaces are no strangers to repurposing outdated tech, and Nottingham Hackspace happens to own one of those oddities one rarely gets their hands on: a railway departure board. Left idle for over a decade, it was brought back to life by [asjackson]. Originally salvaged around 2012, it remained unused until mid-2024, when [asjackson] decided to reverse-engineer it. The board now cycles between displaying Discord messages and actual train departures from Nottingham Railway Station every few minutes. The full build story can be found in this blog post.
The technical nitty-gritty is fascinating. Each side of the board contains 4,480 LEDs driven as two parallel chains. [asjackson] dove into its guts, decoding circuits, fixing misaligned logic levels, and designing custom circuit boards in KiCAD. The latest version swaps WiFi for a WizNet W5500 ethernet module and even integrates the Arduino Uno R4 directly into the board’s design. Beyond cool tech, the display connects to MQTT, pulling real-time train data and Discord messages via scripts that bridge APIs and custom Arduino code.
This board is a true gem for any hackerspace, even more so now it’s working. It waited for the exact mix of ingredients why hackerspaces exist in the first place: curiosity, persistence, and problem-solving. Nottingham Hackspace is home to a lot more, as we once wrote in this introductory article.If you don’t have room for the real thing, maybe set your sights a bit smaller.
Do you have a statement piece this cool in your hackerspace or your home? Tip us!
4 thoughts on “All Aboard The Hack Train: Nottingham’s LED Revival
    1. The original controller is still in the departure board, and left untouched if anyone in the space wants to hack on it later :)
      I did have a play with the built in controller, but couldn’t figure out the modbus registers to get it to do anything. Also, it was power hungry! Used 4-5 times as much as the LED matrices, so not I decided not to use it.
Leave a Reply to CJayCancel reply
