Modern remote control (RC) radios are capable of incredible range, but they’re still only made for line-of-sight use. What if you want to control a vehicle that’s 100s of kilometers away, or even on the other side of the planet? Cellular is an option, but is obviously limited by available infrastructure — good luck getting a cell signal in the middle of the ocean.
But what if you could beam your commands down from space? That’s what [Thingify] was looking to test when they put together an experimental RC boat using a Starlink Mini for communications. Physically, there was no question it would work on the boat. After all, it was small, light, and power-efficient enough. But would the network connection be up to the task of controlling the vehicle in real-time?
Continue reading “Remotely Controlled Vehicles Over Starlink”
