Custom PCB Is A Poor Man’s Pick And Place
Surface mount devices have gotten really small, so small that a poorly timed sneeze can send your 0603 and 0402 parts off to live with the dust motes lurking at the edge of your bench. While soldering such parts is a challenge, it’s not always size that matters. Some parts with larger footprints can be a challenge because of the pin pitch, and getting them to land just right on the PCB pads can be a real pain.
To fight this problem, [rahmanshaber] came up with this clever custom PCB fixture. The trick is to create a jig to hold the fine-pitch parts securely while still leaving room to work. In his case, the parts are a couple of SMD ribbon cable connectors and some chips in what appear to be TQFP packages. [rahmanshaber] used FreeCAD to get the outline of each part from the 3D model of his PCB, and KiCad to design the cutouts; skip to 7:30 or so in the video below if you don’t need the design lesson. The important bit is to leave enough room around the traces so that the part’s leads can rest of the PCB while still having room to access them.
Using the fixture is pretty intuitive. The fixture is aligned over the footprint of the part and fixed in place with some tape. Solder paste is applied to the pads, the part is registered into the hole, and you’re ready for soldering. [rahmanshaber] chose to use a hot plate to do the soldering, but it looks like there’s enough room for a soldering iron, if that’s your thing.
It’s a simple idea, but sometimes the simplest tools are the best. We’ve seen lots of other simple SMD tools, from assembly jigs to solder paste stencil fixtures.
8 thoughts on “Custom PCB Is A Poor Man’s Pick And Place
    1. In genrall this might be true, but having two connectors that have to match exactly in all degrees of freedom, like for the compute module in the video, a stencil or other guide makes this way easier
  1. Normally heavy parts like these have pegs on the bottom to assure correct placement. Especially for board-to-board connectors. Not sure why he picked a version that doesn’t have them. But that’s a nice way of dealing with it.
    1. Not sure if this is the exact case, but it sure looks like it – Raspberry Pi Compute Module 4s have two parallel connectors that have no pegs and need to be placed precisely.
      I made a jig myself for dealing with their placement.
  2. Needing another PCB to reflow a PCB is extraneous. The one advantage I see is that the extra PCB insulates the target PCB substrate so that more heat radiates out through the parts and their corresponding pads. But why add a variable cost to your process (extra PCB) when you can just improve your reflow technique for most likely a fixed cost?
  3. Or you could get your PCB manufacturer to make 2 x laser stencils: 1 for solder paste as usual, and 2nd maybe as thick as allowed, for PCB foot prints as outlined above. My PCB maker charges $10 per laser stencil even with a prototype order.
Leave a Reply to FidCancel reply
