Too Smooth: Football And The “KnuckleBall” Problem
Picture a football (soccer ball) in your head and you probably see the cartoon ideal—a roughly spherical shape made with polygonal patches that are sewn together, usually in a familiar pattern of black and white. A great many balls were made along these lines for a great many decades.
Eventually, though, technology moved on. Footballs got rounder, smoother, and more colorful. This was seen as a good thing, with each new international competition bringing shiny new designs with ever-greater performance. That was, until things went too far, and the new balls changed the game. Thus was borne the “knuckleball” phenomenon.
Smoother Is Better, Right?
An Adidas Telstar from the 1974 World Cup. The original Telstar design actually predates 1974, and the combination of 12 pentagonal and 20 hexagonal panels and black and white patterns had been used before, too. Regardless, the Adidas design was soon globally known, and eventually became the “default” design for a football in media. Credit: shine2010, CC BY 2.0
From the late industrial era onwards, footballs were traditionally made with leather panels wrapped around some form of rubber bladder. As it’s not easy to produce a seamless leather sphere, balls were instead sewn together from individual leather panels in order to create a vaguely spherical whole. Early designs had few panels, and weren’t particularly good at approximating the shape of a sphere. They often had large, wide seams that stretched far across the surface of the ball. Larger seams were by and large undesirable, as they made the ball harder to control. Ridges where the panels met could catch on the foot and lead to unpredictable behavior.
The 32-panel design persisted at the World Cup level until 2002, with the Fevernova ball. Credit: Nicola, CC BY-SA 4.0
Over time, there was a desire to create smoother, rounder balls for professional play. By the 1970s, football designs began to coalesce around a common format. The standard became 12 pentagonal and 20 hexagonal panels, which could be sewn together into a relatively good approximation of a sphere. This  also allowed the construction of a ball with very fine seams, creating a more predictable ball which enabled far finer control. The format was perhaps best popularized by the Adidas Telstar as used in the 1970 and 1974 World Cups. Even though it wasn’t the first to use the 12-and-20 design, the layout and the black-and-white pattern has been firmly etched in footballing consciousness ever since. Indeed, starting at the 1970 World Cup, Adidas has made every following World Cup ball since.
For a time, it seemed as if the design of the football was settled science. Adidas stuck with the 32-panel design up until the 2006 World Cup, when it revealed the +Teamgeist design. It used 14 curved panels that were bonded instead of stitched, creating a smoother ball for yet more predictable handling. It was also intended that the design would be more waterproof, to avoid gaining weight in wet matches. The ball was criticised by some for its erratic flight patterns, but by and large was seen as fit for purpose.
The Jabulani proved controversial, with its ultra-smooth design criticised for creating its unpredictability in flight. Credit: Adidas, editorial use
With another successful World Cup under its belt, Adidas innovated further for the 2010 World Cup. It created the Jabulani, which consisted of just eight spherically-moulded panels bonded together into an ultra-smooth and  cohesive sphere. If the 2006 World Cup ball was slightly controversial, the Jabulani was outrageous. The ball was referred to as “supernatural” for its tendency to suddenly change direction in flight, which pleased strikers to a degree, but frustrated goalkeepers to no end. Ultimately, though, this tendency wasn’t good for getting balls on target. Just 147 goals were scored in the 2010 World Cup, the fewest since the competition changed its tournament format in 1998.
The problem came down to a phenomenon known as “knuckling.” This happens when the ball is travelling through the air with little to no spin. At a certain speed, the seams on the ball tend to interact with the airflow, channeling it such that it creates sudden and unpredictable movements. The term first developed in baseball, but became relevant to football with the development of the 2006 and 2010 World Cup balls, which suffered this phenomenon more often in play.
The phenomenon became so well known that NASA scientists took the opportunity to throw World Cup balls in a test chamber to demonstrate the effects at play. Knuckling behavior tends to peak at a certain critical speed, with the effect lessened either side of the peak. The problem was that the smoother designs were “knuckling” at higher speeds than balls from previous generations. NASA researchers found that the Jabulani would undergo unpredictable flight due to knuckling at speeds of 50 to 55 mph—right around the speed at which professional strikers can deliver a ball to the net. Meanwhile, more traditional 32-panel balls tend to see a peak in knuckling around 30 mph. Since strikers were typically kicking beyond this speed, knuckling—and thus unpredictable flight—wasn’t such a problem with the older designs.
The Brazuca demonstrated a critical knuckling speed closer to a traditional 32-panel ball in NASA’s tests. “What we are looking for in the smoke patterns is at what speed the smoke patterns suddenly change,” notes Rabi Mehta, NASA’s chief of the Experimental Aero-Physics Branch. “This is when the knuckling effect is greatest.” Credit: NASA
Being well aware of the problem after the 2010 World Cup, Adidas went back to the drawing board and developed the Brazuca for the 2014 competition. The number of panels was reduced yet further to just six. However, Adidas wasn’t intending to just go smoother yet again. Instead, the Brazuca had longer, deeper seams than the Jabulani, and panels covered in textured bumps. Through the company’s careful design efforts, this brought the critical knuckling speed back down to around 30 mph, much more akin to a traditional 32-panel ball.
By and large, the Brazuca proved far less controversial than its two predecessors. Search for articles on the 2014 ball, and you’ll find a little speculation from before the World Cup, before the story died completely once competition began. No more were unpredictable balls confounding the world’s finest footballers. Meanwhile, democratically speaking, where the +Teamgeist and Jabulani each have hundreds of words spilled on Wikipedia over controversy and criticism, the Brazuca has none.
Adidas gave the Brazuca deeper seams and a bumpy finish to improve its stability in flight. Credit: Nicola, CC BY-SA 4.0
The story of the Jabulani is one of unintended consequences. Adidas had intended to improve its product in a predictable and routine manner, only to find an unexpected effect at play which threw a spanner in the works. Once the effect was understood, it could be controlled and refined out with careful design. Football hasn’t suffered a “supernatural” ball since, even as the technology marches ever further into the Smart Ball era. Still, who knows what comes next at the 2026 World Cup?
25 thoughts on “Too Smooth: Football And The “KnuckleBall” Problem
      1. There are a lot of other unrelated sports that literally translate to football in regional language or dialect.
        Association Football, or Soccer as the Brits called it when it was popularized in the US, is by far the most popular of the many games called football.
        I’d still rather watch a tennis match than a football game. What is popular isn’t always the best overall or even what should be considered standard. (omg, FIFA is the worst thing to happen to football)
      2. Canada, Australia, and Ireland all have local varieties of football so association football is called soccer. Especially in Canada where both American and Canadian football are popular
  1. I remember the old, truncated icosahedron shaped footballs made of leathery patches.
    Then those cheaply made plastic balls became common place.
    Because: modern, lightweight, futureproof, blah blah blah
    Didn’t feel like a real football anymore, at all, sadly.
    And I’m saying this as someone who isn’t even a football fan! 🤣
  2. What I have always wanted to know is why, when we deliberately add spin to get a ball to bend in flight, the bend goes one way when the ball is a leather soccer ball, and the other way when it’s a light plastic ball on the beach?
  3. I’ve just checked.. It seems that the football with the classic black/white pattern did exist by 1968 already.
    The Adidas Telstar “Elast” was being used in european championship at the time.
    That’s at least what photograpies do suggest when using search engine.
    “Telstar” was a reference to the famous satellite, which the band The Tornados played a song about.
    1. The black/white pattern was a reaction to TV.
      The old school, single color balls were hard to see on early sets.
      It’s a lot like the new Ferrari red deployed with the introduction of color TV.
  4. For me it just smells like a conspiracy to sell more expensive balls. All that “research” has to be paid for by someone right? Do any of those football guys know why golf balls have dimples and tennis balls are woolly? I guess they can spend more research on that. But the soccer industry has plenty of money going round, and with so much money, there are plenty of folks wanting to skim off a bit for themselves.
  5. What a collosal waste of human effort and time, all so one of the most genuinely evil and corrupt corporate bodies can squeeze hundreds of billions of dollars from the world.
    Seriously, I have heard more rational Nazi excusers than some of the things people say to excuse FIFA.
    How can any sane person engage with an organization that literally supports slave labor and markets genuine gambling to children?
    If the world is so awful that we will accept bread and circuses from these kinds of people, maybe we need a change of direction.
  6. As someone who doesn’t sports all that much, let alone professional foozballz, I gotta say this was an entertaining and interesting article. great job writing for the audience. thanks.
    1. word
      I’m happy to see HaD recruiting new writers, I hope that features into who starts writing too. Not that youtube summaries aren’t universally bad, the writing itself is usually OK, but that space is saturated here.
      Anyway, still the absolute best free-forum tech website out there, all said. Thanks for that, editors.
      by and large, you know. lol couldn’t help myself.
Leave a Reply to I Alone Possess The TruthCancel reply
