High-Speed Reservoir Computing With Integrated Laser Graded Artificial Neurons
So-called neuromorphic computing involves the use of physical artificial neurons to do computing in a way that is inspired by the human brain. With photonic neuromorphic computing these artificial neurons generally use laser sources and structures such as micro-ring resonators and resonant tunneling diodes to inject photons and modulate them akin to biological neurons.
General reservoir computing with laser graded neuron. (Credit: Yikun Nie et al., 2024, Optica)
One limitation of photonic artificial neurons was that these have a binary response and a refractory period, making them unlike the more versatile graded neurons. This has now been addressed by [Yikun Nie] et al. with their research published in Optica.
The main advantage of graded neurons is that they are capable of analog graded responses, combined with no refractory period in which the neuron is unresponsive. For the photonic version, a quantum dot (QD) based gain section was constructed, with the input pulses determining the (analog) output.
Multiple of these neurons were then combined on a single die, for use in a reservoir computing configuration. This was used with a range of tests, including arrhythmia detection (98% accuracy) and handwriting classification (92% accuracy). By having the lasers integrated and the input pulses being electrical in nature, this should make it quite low-power, as well as fast, featuring 100 GHz QD lasers.
2 thoughts on “High-Speed Reservoir Computing With Integrated Laser Graded Artificial Neurons
  1. I’m actually going to OFC in San Francisco this year, but I have no idea what this article is talking about :)
    However you did make me realize where the company name Lightmatter comes from, instead of graymatter they use light to make neurons. Very clever.
Leave a Reply to onoCancel reply
