The Mysterious And Important Work Of Prop Design On Severance
Have you seen Severance? Chances are good that you have; the TV series has become wildly popular in its second season, to the point where the fandom’s dedication is difficult to distinguish from the in-universe cult of [Kier]. Part of the show’s appeal comes from its overall aesthetic, which is captured in this description of the building of one of the show’s props.
A detailed recap of the show is impossible, but for the uninitiated, a mega-corporation called Lumon has developed a chip that certain workers have implanted in their brains to sever their personalities and memories into work and non-work halves. The working “Innies” have no memory of what their “Outies” do when they aren’t at work, which sounds a lot better than it actually ends up being. It’s as weird as it sounds, and then some.
The prop featured here is the “WoeMeter” from episode seven of season two, used to quantify the amount of woe in a severed worker — told you it was weird. The prop was built by design house [make3] on a short timeline and after seeing only some sketches and rough renders from the production designers, and had to echo the not-quite-midcentury modern look of the whole series. The builders took inspiration from, among other things, a classic Nagra tape recorder, going so far as to harvest its knobs and switches to use in the build. The controls are all functional and laid out in a sensible way, allowing the actors to use the device in a convincing way. For visual feedback, the prop has two servo-operated meters and a string of seven-segment LED displays, all controlled by an ESP-32 mounted to a custom PCB. Adding the Lumon logo to the silkscreen was a nice touch.
The prop maker’s art is fascinating, and the ability to let your imagination run wild while making something that looks good and works for the production has got to be a blast. [make3] really nailed it with this one.
Thanks to [Aaron’s Outie] for the tip.
28 thoughts on “The Mysterious And Important Work Of Prop Design On Severance
  1. Beautiful prop! And great example what can be done with just a few parts!!
    Just a tech one – the needles are steered by stepper motors, not servos. Looks like small car dash gauge steppers … aaand based on the pictures, they indeed are: x27 168 https://www.adafruit.com/product/2424 driven by TB6612 stepper drivers (quite massive for the job, such needle gauges could be perhaps driven directly by ESP32 as they eat just about ~15mA max? But this is on the really safe side.)
    1. Not everything has to be cost-optimised, especially when it’s a one-off. Development time, repairability and robustness are far more critical. And while you might be able to crudely drive a stepper by manually bit-banging digital waveforms, actual high-quality smooth stepper control is much more complex, and yet easily achieved by just using the parts specifically designed for the purpose.
  2. The aesthetics are among the most compelling aspect of this show IMO. Story wise, feels like they’ve already told it in season 1… but I’m still watching it for the visual stimulation.
    That being said, this prop is a great example why this show looks so compelling (albeit sterile and unpleasant).
  3. It’s clear that it is based on a real device by a very popular cult that will immediately sue if you call them that. They had a very charismatic dude as leader, obsessed with sailing, writing great sci-fi about nukes, DC-10s and aliens. For my safety I have forgotten his name. His haters say he was an undiagnosed schizophrenic who hated psychiatry.
    1. Only the sci-fi novel turned into a terrible vanity movie by one of his very famous celebrity cult members was good. His string of instantly forgettable pulp novels were awful and amateurish.
      1. I read somewhere in the distant past that someone did some analysis on the book and figured it was written by three different people just due to stylistic differences. I still have a copy somewhere, and it’s a fun romp of escapist “humans will survive and conquer against all odds!” tropes.
        I’d love to see Christopher Rowley’s “The Starhammer” turned into a movie!
  4. Lack of a tinted window over the LED display always ruins it for me, but I’ll be generous and allow that there might be a cinematographic reason to leave it off ;)
    1. I guess it’s because green LEDs look bright enough to humans even at very low intensities, but not so bright to cameras unless it’s exactly the right color to match the camera’s green filter (indicator LEDs are rather monochromatic), so they left the tinted window out to be visible.
  5. While I’m in my armchair, here’s another criticism of this cool prop:
    The “wiggling” of the needle, as shown in the sample footage, could have been done better. Either an actual coil spring between the shaft of the stepper and the needle, or a spring simulation in software, would have given it a better d’Arsonval meter feel.
    See: https://en.wikipedia.org/wiki/Hooke%27s_law
  6. As a props builder for film and TV, Severance is a really well designed show, and it’s inspiring/ frustrating to read the article about how they built it. There are SOME prop shops/ builders which get the time and money to massage these amazing pieces into life, but 99.9% of the time being a prop builder is basically having some stressed out Propmaster/ Production Designer spend five minutes telling you they don’t know what they want and then having to spend however long it takes kitbashing something into existence from existing parts because they need if yesterday and they don’t have any money, yet apparently everything you do needs a small change making after you have done it. Sometimes you do your best work when you have the time and budget and artistic vision, most of the time you do your best work when you have to pull something out of nothing.
    1. Priest of ducks, with feathers so bright,
      I write to you today, with a humble request in sight.
      Your activities, though profitable, I must confess,
      Have raised concerns, and I implore you to take a rest.
      The impregnation of ducks, a practice so fine,
      Must be halted, I ask, until a certain time.
      For when children are present, with eyes so wide,
      It’s essential to consider their sensitive inside.
      Their young minds, so pure, and full of wonder and glee,
      Must be shielded from sights, that may not be suitable to see.
      The process, though natural, may raise questions and fears,
      And as a responsible adult, it’s our duty to claim their tears.
      So I ask you, dude, to cease your activities for now,
      Until the children are done, and the crowd is more mature somehow.
      Let us prioritize their well-being, and their innocent eyes,
      And resume your work, when the time is more suitable, and the crowd is more wise.
      I understand your business, and the importance of your trade,
      But I hope you can understand, the concerns that I’ve conveyed.
      Let us work together, to find a solution that’s fair,
      And ensure that your activities, do not disturb the children’s air.
      So please, man, take a beak from your duck impregnation activities,
      Until the children are impregnated too, and the crowd is eager to see.
      Let us prioritize their well-being, and their sensitive young minds,
      And resume your work, when the time is right, and the crowd is more kind.
  7. I’d would have go for the aluminium version with wooden pads instead of plastic to close the enclosure ( like chesnut wood).
    But it’s down to personnel preferences as I haven’t watched the show !
    Nice propose !
Leave a Reply to Raymond AldermanCancel reply
