2025 Pet Hacks Contest: Weigh Your Dog The Easy Way
If you need to weigh your pet, you’ll soon find that getting an animal to stand on a weighing machine to order is very difficult indeed. If the critter in question is a cat or a small dog you can weigh yourself both holding them and not holding them, and compute the difference. But in the case of a full size Bernese mountain dog, the hound is simply too big for that. Lateral thinking is required, and that’s how [Saren Tasciyan] came up with the idea of making a dog bed that’s also a weighing machine. When the mutt settles down, the weight can be read with ease. The bed itself is a relatively straightforward wooden frame, with load cells placed above rubber feet. The load cells in turn talk to an ESP8266 which has an LCD display to deliver the verdict. Dog weighed, without the drama.
This project is of course part of the Hackaday 2025 Pet Hacks contest, an arena in which any of the cool hacks you’ve made to enhance you and your pet’s life together can have an airing. Meanwhile this isn’t the first time this particular pooch has had a starring role; he’s sported a rather fetching barrel in a previous post.
4 thoughts on “2025 Pet Hacks Contest: Weigh Your Dog The Easy Way
  1. Nursing homes have walk-on scales with ramps on either side of the weighing platform so the client can be walked, rolled or otherwise put on the platform. Ramp. Sometimes the simple machines are the best.
Leave a Reply to I Alone Possess The TruthCancel reply
