Audio Localization Gear Built On The Cheap
Most humans with two ears have a pretty good sense of directional hearing. However, you can build equipment to localize audio sources, too. That’s precisely what [Sam], [Ezra], and [Ari] did for their final project for the ECE4760 class at Cornell this past Spring. It’s an audio localizer!
The project is a real-time audio localizer built on a Raspberry Pi Pico. The Pico is hooked up to three MEMS microphones which are continuously sampled at a rate of 50 kHz thanks to the Pico’s nifty DMA features. Data from each microphone is streamed into a rolling buffer, with peaks triggering the software on the Pico to run correlations between channels to determine the time differences between the signal hitting each microphone. Based on this, it’s possible to estimate the location of the sound source relative to the three microphones.
The team goes into great deal on the project’s development, and does a grand job of explaining the mathematics and digital signal processing involved in this feat. Particularly nice is the heatmap output from the device which gives a clear visual indication of how the sound is being localized with the three microphones.
We’ve seen similar work before, too, like this project built to track down fireworks launches. Video after the break.
11 thoughts on “Audio Localization Gear Built On The Cheap
  1. Very cool! I think this could be a useful handheld tool if you could filter the frequencies to those above a certain frequency. Finding something with a very high pitch intermittent beep (e.g. fire detector with a low battery) can be difficult sometimes as the sound bounces off stuff. I had this problem a couple months ago and it took a solid 10 minutes to locate it within a room.
  2. If I have understood, with just 2 microphones, the single hyperbola can still indicate the direction of the sound, but would of course not show the 3D information, the intersection of 2 hyperbolas as so nicely shown.
    So then say you had a number of these 2 mic setups in a forest, with something like a lora network sending direction back to a base. Surely that received direction data alone would be enough for the base to do the grunt work in order to surmise the rough location of a loud noise, likely much further away.
    Maybe I have misunderstood?
    This is important because most systems I have read about seem to rely on comparing absolute time of arrival of a loud noise event, a bit of a nightmare which hinges on the sychronisation of clocks.
    1. I’d say you need at least 16 mics in a specific pattern to provide a really useful level of resolution
      it’s not all time of arrival though. You can decode the position of waves based on partial information at each sensor. think of it like a soundwave that is X cm long, and that wave is then going to hit a number of different sensors in the field at the same time, dependent on it’s length
      but yes, aggregating and synchronizing the data is non-trivial. It is possible with expensive FIFO based IC arrays and some clever math. you have to be able to account for reflections and surface contact wave deformation and that kind of stuff. It’s actually very complex to do it well
      this project is on the level of a toy, not especially useful
    2. US army already has something like this to detect where shots are comming from. It has at least 5 or 6 michrophones. It was mounted on a Humvee. This is 5 years ago or more. I cannot remember if it was just testing or if it was starting to be implemented.
  3. Adam Savage recently used the Fluke ii910 Precision Acoustic Imager to find an air leak in the plumbing for the compressor in his shop. It looks kinda like a tablet with an array of microphones on the back. It showed exactly where the leak was in his air system plumbing. He also used it to find a leak in a bicycle inner tube, even when there was a lot of background noise. Very cool tech.
  4. I like the idea of having students figure out how to squeeze every cycle/bit out of hardware, but if one weren’t tied to the pi pico, the almost-as-cheap esp32s3 has some SIMD instructions, 2 cores, and a nice dsp library. FFT on 1024 16bit-complex samples takes about 60 usec on one core (cores have independent simd coprocs).
    https://github.com/espressif/esp-dsp
  5. Just a few months ago I did a very similar project with almost exact same hardware for my iot course, I wish our institute made us write hackathon posts that way I wouldn’t have dared to fake it. I ended just comparing amplitudes for we ran out of time to dial in the time of flight based system. Our project was to make a very cheap haptics based awareness device for dead people. Maybe with a bit more compute power and few more software filters this can be turned into one. Really excited to see someone archive this (when I started researching about this, all I was able to find ways slightly discouraging articles on Arduino forums) and now somebody has done it.
Leave a Reply to make piece not warCancel reply
