Hacking Printed Circuit Board To Create Casing And Instrument Panels
A photo of the PDP-1 replica.
Over on Hackaday.io our hackers [Angelo] and [Oscarv] are making a replica of the PDP-1. That is interesting in and of itself but the particularly remarkable feature of this project is its novel use of printed circuit boards for casing and instrument panels.
What does that mean in practice? It means creating a KiCad file with a PCB for each side of the case/panel. These pieces can then be ordered from a board house and assembled. In the video below the break you will see an example of putting such a case together. They use sticky tape for scaffolding and then finish things off by soldering the solder joints on each edge together.
We cover so many PCB hacks over here at Hackaday that we have an entire category dedicated to them: PCB Hacks. If you’re interested in PCBs you might like to read about their history, as before they were everywhere they were nowhere.
Thanks to [Oscarv] for writing in to let us know about this one.
11 thoughts on “Hacking Printed Circuit Board To Create Casing And Instrument Panels
  1. Funny I learned this trick years ago from a hack a day article. Surprised it doesn’t turn up more often as many goofball “pcb as art” badge projects gets posted here.
    One trick I did a while ago (which wouldn’t really fit this project) was back lit indicators by removing the copper layers and solder mask using the text I wanted.
  2. I’m making panels from aluminum PCB’s. Since I’m familiar with kicad for designing them and JLC produces them very cheap.
    Routing and dril holes are perfect and so is the white coated surface finish. The black silkscreen printing is s little low resolution but nothing that bothered me.
  3. I love Oscar’s work. He doesn’t just create a work-alike classic computer, but goes the extra 1,000 kilometers and makes a scaled down version of the case and front panel that work like the original. So cool. He’s been at the Vintage Computer Festival Eastm several times, always good to see him and chat.
  4. Years ago, I played Spacwar! on THE PDP-1 – the one at MIT
    Later on Data General Nova computers at Smithsonian Astrophysical Observatory, when the room was too hot to run the hard drives. (Pigeon feathers in the air conditioners). A quite interesting summer job, back when computer graphics hardware was expensive.
Leave a Reply to John Elliot VCancel reply
