The WHY 2025 Badge And Its 18650s
The largest European hacker camp this year was in the Netherlands —  What Hackers Yearn (WHY) 2025 is the latest in the long-running series of four-yearly events from that country, and 2025 saw a move from the Flevoland site used by SHA2017 and MCH2021, back to just north of Alkmaar in Noord-Holland, where the OHM2013 event took place. WHY has found itself making the news in the Dutch technical media for all the wrong reasons over the last few days, after serious concerns were raised about the fire safety of its badge.
The cell supplied with a WHY 2025 badge, with very clear fire safety warning
This is the cell supplied with the WHY badge, complete with manufacturer’s warning.
The concerns were raised from the RevSpace hackerspace in Leidschendam, and centre around the design of the battery power traces on the PCB between the battery holders and the power supply circuitry. Because the 18650 cells supplied with that badge lack any protection circuitry, bridging the power traces could be a fire risk.
In short: their report names the cell holders as having tags too large for their pads on the PCB, a too-tight gap between positive and negative battery traces, protected only by soldermask, and the inadequacy of the badge’s short circuit protection. In the event that metal shorted these battery tags, or wore through the soldermask, the batteries would be effectively shorted, and traces or components could get dangerously hot.
The WHY organizers have responded with a printed disclaimer leaflet warning against misuse of the cells, and added a last-minute epoxy coating to the boards to offer additional protection. Some people are 3D-printing cases, which should also help reduce the risk of short-circuiting due to foreign metal objects. Using an external powerbank with short-circuit protection instead of the cells would solve the problem as well. Meanwhile a group of hackers collecting aid for Ukraine are accepting the batteries as donations.
It’s understood that sometimes bugs find their way into any project, and in that an event badge is no exception. In this particular case, the original Dutch badge team resigned en masse at the start of the year following a disagreement with the  WHY2025 organizers, so this badge has been a particularly hurried production. Either way, we are fortunate that the issue was spotted, and conference organizers took action before any regrettable incidents occurred.
38 thoughts on “The WHY 2025 Badge And Its 18650s
  1. “The group that brought the 18650 concerns to light has some overlap with the group that left the WHY2025 badge project”
    No shock there and it seems much ado about very little. If my cellphone gets stabbed the battery might conflate in a giant fireball. If my car hits a wall I might die.
    These are all fairly obvious things, just like bridging + and -, and wearing through soldermask to bridge connections…
    1. with your mindset we would still have quicksilver thermometers and cars without safety belts…
      a badge is, should, must be considered – and is a good exercise in doing – a product, with safety norms and good practices that apply.
    2. If you hand things to kids, they should be safe.
      These cells are specifically prohibited by the manufacturer from use as it has been used by Team:Badge / WHY2025
      So, they ignored the warning by the manufacturer AND the additional research by members of the hacker scene.
      They could have chosen to only power it through powerbank, completely removing the danger.
      They chose to keep some of the danger there.
      Meanwhile they are completely responsible for any form of danger/damage by this badge.
      This is not something I make up, it has been completely nerded out by multiple people on camp.
      Even with the extra information, it is still in their hands. Yes, these are obvious, but also avoidable dangers.
        1. You do not get the point.
          risk is part of life. But for some things, we should avoid possibility of harming others
          If you have that choice, you choose for something not harmful.
          1. So you don’t buy anything from aliexpress nor leave your house. Gotta avoid all possible risks afterall, including unlikely ones (or ones unintentionally done)
    3. But your cellphone doesn’t have exposed PCB with leads unprotected by any current limiter and isn’t worn on a leash with some other metal objects banging on it all day.
      1. My car is subject to some dude have asleep at the wheel or eating/shaving/screwing with his phone. So yeah I would say the same level of risk.
        Been a while since I have been to a con, but the few badges I had had cases.
    4. If my car hits a wall I might die.
      Idk if I buy this. I recently ran my car into a wall and flipped over, and I didn’t die, nor did I even get hurt. Had to get a new car tho…
  2. (Editor’s note: the group that brought the 18650 concerns to light has some overlap with the group that left the WHY2025 badge project.)
    This is not correct. I was part of the original team and didn’t know of the 2 weeks of talks with the camp orga and Juerd doing the investigation. I just wanted a quiet drive on last Wednesday to WHY and in the morning I saw that I had 100s of messages to read. But all our fears of using 18650 cells on a badge were confirmed.
    The investigation was done independently from Badge.Team in order to remain impartial. The team doing the investigation had a hard time to find dudes who know electronics and we’re separate from Badge.Team. Ironically they found 2 designers of the WHY2025 badge who were worried and helped.
    More info via Juerd.
    Regards,
    Jelle Haandrikman / Treasurer Badge.Team
  3. “has some overlap with the group that left the WHY2025 badge project.”
    Hi, I am the author of the analysis document and part of the group of people who found and reported the issues. I am neither part of Badge.Team (the team that left) nor Team:Badge (the current team). I am, however, part of the “orga” of the event itself.
    In fact, I carefully avoided contacting anyone from Badge.Team during the past few weeks, to avoid exactly this. They only found out late in the disclosure timeline. Please remove this part of the article since it is just not true.
  4. For commercial products, you’re supposed to put it in a case if you’re using cells without short circuit protection. But you’re also supposed to have a case for pouch cells regardless of protection circuitry, because puncturing a lithium pillow is often firey.
    In the badge scene, I have seen more exceptions to these two rules than I have seen conformity. I’ve also seen a lot more conventional cells used than lithium, probably because people are afraid of the pitfalls.
    I think it’s good that we are having this discussion, though, because I don’t think we have a consensus about what constitutes acceptable risk, and what the right safety precautions are for badges / hacks / prototypes.
    Relevant standards for commercial stuff:
    IEC 62133: Safety requirements for portable sealed secondary cells
    UL 1642: Standard for Lithium Batteries
    EN 62133: European standard for secondary cells and batteries
    1. True. I view badges as the hacked together things they are. There will always be some level of risk as a result, and this is the same level as other battery powered things….dont short it.
      heck Samsung had the Note 7’s exploding as an example of a huge company getting it really wrong…., and most of the people on here shaming the badge team likely buy and use dodgy products from aliexpress.
      Risk free is not using or tinkering with electronics yet nobody here is gonna do that.
    2. Am I that old to think we have, as children, survived way worse threats?
      Those badges are not a sold with warranty supersafe products, are they? I wish people be reasonable. Buy and then sue should not become standard and affect normal life. Well, I’m probably old.
  5. Maybe I’m a stick in the mud, but “Badge Life” is basically premeditated e-waste the moment you set foot out of an event. And yeah, that bothers me.
    I do have a few badges as well. Haven’t touched them since I got them years ago. I did disconnect the batteries however.
    1. E-waste is relative, as it’s unlikely anyone will throw away the badge, as even if it is not used it’s a keep sake. Furthermore, badge life is also about enabling thousands of hackers to to tinker with the latest and greatest chips. In this case, a new Espressif chip which isn’t widely available yet.
      1. E-waste is relative… what does that even mean?
        What might be a keepsake for now WILL be discarded eventually. Perhaps not by the person who bought it, but most certainly by the person who inherits it.
        So, if you like it or not, each and every badge WILL be discarded whether you like it or not. It might take a few years to a few decades but eventually it goes into the trash. E-waste is not changing into non e-waste by putting it in a drawer for 2 decades before tossing it in the bin.
        1. My biggest issue with calling badges premeditated e-waste is that it’s true for any electronic gadget you acquire. Yet, I never read the same argument when people purchases a new phone as soon as a newer model is available. Similarly, a vendor handing out dev boards isn’t considered premeditated e-waste, either. Just the way of getting hardware in the hands of potential customers.
          A good badge provides a use long after the event. At the Dutch hackerspaces we still use the SHA2017 badges for displaying CO2 levels, weather forecasts, and train schedules. Of course, this is the exception and I rarely see MCH or CCC badges ‘in the wild’.
          A way events already change is that badges are now less frequently available for all participants. You can now purchase the badge in advance at several events. I do have to admit that I have rarely used my badges. Several even left unopened. Yet every one of them is a piece of art which holds memories to the event.
          1. Unfortunately, I didn’t attend an event I would get such badge yet. But I truly do not consider it e-waste at all. Even if it would sit in my drawer for ages (well, as if I didn’t already have many “drawers” filled with such might-get-handy-once gizmos).
            Unlike, as you mention, new phones to support manufacturers’ revenues.
            In comparison, I think when it gets to e-waste, the ratio around the globe between commercial consumer electronics and made for hobby fun stuff goes way to the detriment of the commerce….
    2. The Dutch hacker event badges have as an explicit design goal to avoid exactly this fate for as long as reasonably possible. Many use a common esp32 core with backward and (limited) forward compatibility, to promote porting apps to whatever badge people have. There’s a common app format and a “store” where users can upload their projects and download projects from the badge itself. Most are also esphome-able.
      This works quite well in practice, too. You still see apps being sent around and posted for badges from years back. At hackerspaces and at the homes of my hacker friends (including mine) you’ll see badges from SHA to Hacker Hotel running all kinds of minor infrastructure. My SHA badge is a small display by the door with upcoming rain predictions, for example. I would’ve probably bought a small screen and MCU board for this, but didn’t have to, because I had a SHA badge already~
      The WHY2025 badge was a messy launch, but even in the rushed firmware production, they still managed to include an app store, and people designed wall-mount cases during the event so the badges could live on at people’s homes and hackerspaces (presumably safely connected to a DC adapter 😅).
      None in the electronics hobby are free of sin w.r.t. e-waste, but I’ve been really impressed at how the Dutch hacker community has approached it, namely by avoiding it as a design goal for most of the badges of the last decade.
  6. Aside from the (potential) fire hazard: If a badge requires two 18650 batteries, it might be a sign that feature creep got out of hand. What fraction of attendees is going to install and learn ESP IDF? While camping, and having fun with friends?
    The badge for the 2024 Supercon was one of the simplest (admittedly, I was a bit disappointed when it was first revealed), but it allowed attendees of all skill levels to hack on it. It probably triggered more engagement than the epic badges from previous years combined, and likely for a fraction of the cost and heartburn.
  7. Hey, strange that no one is mentioning that the badges weren’t available until last days of the camp and on the last day they just ran out and lot of people didn’t get one after paying 350 for a ticket.
      1. The amount of chaos with the badge handouts, and the lack of information about it is probably worth mentioning if you decide to cover the organizational issues in another article. That on the last day the handout was announced 36 minutes before it started without any prior information (even on if there was going to be another handout) hints a lot at the problems of the whole process. It is specially sad that there were advertisements of people selling badges on the badge tent when others couldn’t even get one.
        For me the impact of this chaos, was quite noticeable, on SHA 2017 I wrote quite a few apps for the badge because I had time to do so as I got the badge early on (and the micropython interface made approaching the badge fairly easy). On WHY 2025 I got my badge during the last handout, without time to ever get acquainted to it during the event. I could barely go through the sponsor carrousel. In fact I doubt I will even try to develop any APPs for it even if I’m significantly more experienced with the esp-idf than I was eight years ago, I just won’t have the time or the interest.
    1. While the ticket price was quite steep, only a small fraction went to the badge. A back of the envelope calculation gave me a number not more than €10 per person. There should have been enough badges, so it may get a follow-up. I’ve not received a badge myself, and hope for a rerun without the 18650 sockets.
      Still, it’s a freebee and not something you’ve bought. Some people fell over that the wiki stated “everyone gets a badge”. Where I always read it as ‘we strive to X’. As teardown is still underway, I don’t expect an update before September.
  8. The difference between consumer safety standards and prototypes. If no safety conformance testing, then there should be R&D disclaimers that are accepted by the participants receiving badges.
Leave a Reply to Jelle HaandrikmanCancel reply
