An Amiga Demo With No CPU Involved
Of the machines from the 16-bit era, the Commodore Amiga arguably has the most active community decades later, and it’s a space which still has the power to surprise. Today we have a story which perhaps pushes the hardware farther than ever before: a demo challenge for the Amiga custom chips only, no CPU involved.
The Amiga was for a time around the end of the 1980s the most exciting multimedia platform, not because of the 68000 CPU it shared with other platforms, but because of its set of custom co-processors that handled tasks such as graphics manipulation, audio, and memory. Each one is a very powerful piece of silicon capable of many functions, but traditionally it would have been given its tasks by the CPU. The competition aims to find how possible it is to run an Amiga demo entirely on these chips, by using the CPU only for a loader application, with the custom chip programming coming entirely from a pre-configured memory map which forms the demo.
The demoscene is a part of our community known for pushing hardware to its limits, and we look forward to seeing just what they do with this one. If you have never been to a demo party before, you should, after all everyone should go to a demo party!
Amiga CD32 motherboard: Evan-Amos, Public domain.
27 thoughts on “An Amiga Demo With No CPU Involved
  1. but because of its set of custom co-processors that handled tasks such as graphics manipulation, audio, and memory.
    This was actually copied from arcade machines and other game consoles, when the company first intended to make the machine into a game console. The chipset would have been the “CPU” of the machine and where the 68000 CPU sits would have been a ROM chip in a game cartridge, with the optional extra CPU with its own memory.
    The designers pivoted it into a personal computer by doing exactly that: instead of a cartridge, a 68000 CPU and memory. That’s why there’s two memory buses and two different types of RAM. and the custom chipset sits in the midde of it.
    If they had made it into a personal computer to begin with, they would have gone PC style with a common backplane bus between memory, CPU, and additional hardware, with the chipset present as an “accelerator” card.
    The way it was originally supposed to work. The boot ROM initializes the chipset to read off the game ROM and then Bob’s your uncle. They’re just starting with the data in chip RAM.
    1. Tell me you don’t know anything about building PCs without telling me you don’t know anything about building PCs /s
      RAM and PCI-X buses are not connected together, you can’t plug you GPU into a RAM socket, it won’t work.
      1. Also note that while today on a PC we have bridge controllers (“chipsets”, north bridge, south bridge) to address peripheral buses and other hardware, in the original IBM PC specs the CPU sits directly on the same bus as everything else and acts as the master controller. So in effect your RAM is on the same bus as your graphics card and you could, in theory, plug a GPU into a RAM socket.
        https://image1.slideserve.com/3396245/pc-architecture-l.jpg
        Part of the reason why the Amiga was supposed to be superior was because the chipset did the work of a bus controller, so the CPU didn’t have to. However, since so much of the functionality was tied and integrated to the chipset, it couldn’t be upgraded without breaking compatibility. Then PCs started introducing separate bus controllers to offload the task from the CPU, and the advantage was lost.
        1. in the original IBM PC specs the CPU sits directly on the same bus as everything else and acts as the master controller.
          Not just that awful slow PC 5150, the IBM PC/AT Model 5170 was still same here, too.
          IBM sold memory boards for AT bus, even.
          https://minuszerodegrees.net/5170/cards/5170_cards.htm
          Back in the day it was just normal that the processors’ front-side bus was connected to the expansion slots.
          The concept of chipsets arose in an effort to dec-ouple the main processor and the expansions bus (and peripherals).
          Another concept introduced with i486 was the use of clock-doubling.
          The CPU would internally run twice the external speed.
      2. PCI-X, along with PCIe which you meant to say, didn’t exist before the year 2000.
        Not only can you plug a GPU into a RAM socket, but you won’t have much other choices for another 5 years when the industry moved the video memory back into the video chip again instead of used the much cheaper system dram.
        Lastly by PC I can only assume you really do mean PC. This isn’t a PC. Even so, PCs absolutely do let you access memory boards on the ISA bus along with video cards. By this time IBM had a few pioneer examples to pick one to copy, and that’s exactly what they did.
      3. Pci-x is an extension of the older PCI bus and has nothing to do with graphics cards as it was mostly used for at the time high end storage controllers, you are confusing it with PCI express.
        1. First off, PCI is a general purpose expansion slot and it WAS USED for graphics cards. However, better cards used the AGP port when it came out. VESA local bus that was inline with the longer ISA slot… was on machines in the 486 and essentially overlapped the time PCI was introduced and when AGP came out. 486s would sometimes have a PCI slot. Pentium came out with PCI with 2 ISA slots. Few had VESA local bus. When AGP came out, the VESA local bus was discontinued. Then a little later, ISA slots disappeared and made room for more PCI slots. Before PCI, during the grand old days of MS-DOS… often with no Windows and that PC GEOS aka Geoworks Ensemble was more popular than Windows but MS-DOS was king because even PC-GEOS and pre-Windows 95 / NT required MS-DOS installed as they were more like operating environments and PC-GEOS had a preemptive multitasking kernel. Back in DOS was king of IBM PC & compatibles, the slots were ISA. Two versions. The more common 16 bit, with had 8bit mode and original 8 bit. There may be a nitpicking on the exact numbers but for simplicity sake, it was mainly two general versions. It is true with the unified system bus. There wasn’t multiple busses on the motherboard. It was basically architecturally similar to the C64, original Apple II, and another of others. Things got more complicated in the 32b era and progression of PC to be more AMIGA like but on x86. They worked to steal ideas and implement in a new way distinct to that of Commodore IP. I know the Amiga story. I am not getting into all of it. Over time, the idea AMIGA pioneered eventually was employed by PC even to this day where a lot is offloaded and use the CPU less for things GPU was good at…. Given they all have built-in blitter technology and more. The CPU is still powerful number cruncher which was a good thing for a powerful CPU that is internally faster than the system bus. One could decentralized the CPU into multiple chips but they integrated memory controller, PCI-E, and so on into the CPU so you can have things like sata, m.2, and all…. otherwise the PCB real estate of the motherboard would be consumed by a chip or two…… and surrounding traces connecting it with CPU so where will you have the m.2, sata ports and all? You would have a motherboard on average about 1.25 to 1.5 times the size of those dual XEON server boards…. about the size of a video arcade coinop motherboard…. think SERVER motherboard size like 18×24 inch sheet size. This would make the PCB alone around $150 blank copper cladded FR4. Etched, components and sockets soldered…. that would be north of $500. Talking $1200-$1500 without cpu/mpu, RAM, and video card, but includes the support chips. CPU and RAM, add $500 for modest. Add $750 to $1500 for modest level naming video card. It would skyrocket to over $15,000 for high end. Luckily we have not got to that point.
    2. Probably doable using both copper lists and modifying the inactive copper list from the active one. Tried something like that myself many years ago but I couldn’t quite get it working. I also included the blitter though, I think that was the part that failed
    3. That’s not at all how the Amiga does or ever was designed to work.
      Amiga didn’t “copy” anything from the arcade. Arcades used almost exclusively commodity parts from Zilog, TI, etc. The only thing custom about them were the ROMs and board layouts.
      1. Actually, the Amiga originally was an arcade development platform. The Amiga 1000 if I recall was the guts of a few units. Again, if I recall, the a500 was in some units as well.
        1. Erm no. This is completely false. Search Google you will find the Amiga was bespoke. Had nothing to do with arcade. The first one was built from custom boards (over 5 of them) and was shown in 1993 without a case. Before Atari and then Commodore bought it.
          The history is all on wiki too. The A1000 was the first production machine… Launched in New York with Andy Warhol E and Debbie Harry. It was the art machine before Mac copied it.
          1. Game consoles of the time were far simpler. The idea of using a blitter and other dedicated special purpose chips was borrowed from arcade machines that were starting to use them to accelerate graphics.
            https://en.wikipedia.org/wiki/Robotron:_2084
            A custom blitter chip generates the on-screen objects and visual effects. It transfers memory faster than the CPU, allowing the game to simultaneously animate a large number of objects.
            The point of the Lorraine/Amiga as a gaming system would have been to put arcade style graphics into a home system, making it much more powerful than what was on the market at the time. Then came the video game crash and the market for new consoles dried up, so they pivoted it into a personal computer.
  2. I wasn’t a computer designer, but I sure do miss my Amiga. I had the E plant board to run Mac emulation and it ran benchmarks faster that the SE30 did native. I could cut and paste from the Amiga side to the Mac emulation to the 386 board that I had running as well. With some care with partition permissions I could copy files from one environment to another.
    I was a graduate student and the data analysis program I ran was written by a buddy and ran on the Mac. I wrote my thesis in AmigaTEX. I started on an A500, then the A2000, then an A3000. I gamed a little, not a lot.
    The graphics performance was amazing.
    Support for external video sync was great too. And while not exactly portable, I took my A500 to New Orleans and used my GFs TV as my monitor.
    Of all the machines I ever used, the Amiga was my favorite. Commodore had no clue.
    SLAC used them as real time graphical front ends for their IBM mainframes glueing it together with ARex. One time the IBM brain trust was out. Thier response? “We can’t do that.”
    It’s no wonder the user community is still do strong. It was a unique machine with amazing capabilities. Add a Video Toaster and you had a recording studio.
    What a time!
      1. I haven’t thought of Willi in years. He gave me a printed , in red of course, copy of the VLT manual at an Amiga developers conference. A really sweet guy. VLT was really something, I used it a lot and it combined with arexx could be use to build all manner of of things.
        Thanks for reminding me.
    1. Ah man, I used Video Toaster in elementary school working on the weekly announcement broadcast. It was probably not worth the time, but it got me and my friends interested in computers and video production. I remember screwing around for hours trying to make a 3D asteroid to work right from an old binder of documentation. We were messing around with the BASIC bananas game a lot too, at the time.
      I kinda wish I could even remember the names of those classmates.
  3. So the CPU is only used to load up, then you would use the Copper List the run the demo? If I recall the COPPER has only 3 opcode instructions (move, skip, wait). I guess that is how they do it, eh?
Leave a Reply to Allan SutherlandCancel reply
