Bare Metal STM32: The Various Real Time Clock Flavors
Keeping track of time is essential, even for microcontrollers, which is why a real-time clock (RTC) peripheral is a common feature in MCUs. In the case of the STM32 family there are three varieties of RTC peripherals, with the newest two creatively called ‘RTC2′ and RTC3’, to contrast them from the very basic and barebones RTC that debuted with the STM32F1 series.
Commonly experienced in the ubiquitous and often cloned STM32F103 MCU, this ‘RTC1’ features little more than a basic 32-bit counter alongside an alarm feature and a collection of battery-backed registers that requires you to do all of the heavy lifting of time and date keeping yourself. This is quite a contrast with the two rather similar successor RTC peripherals, which seem to insist on doing everything possible themselves – except offer you that basic counter – including giving you a full-blown calendar and today’s time with consideration for 12/24 hour format, DST and much more.
With such a wide gulf between RTC1 and its successors, this raises the question of how to best approach these from a low-level perspective.
You Can Count On Me
If it was just about counting seconds, then any of the timer peripherals in an MCU would be more than up to the task, limited only by the precision of the used system clock. The RTC requirements are a bit more extensive, however, as indicated by what is called the backup domain in F1 and the backup registers in the RTC2 and RTC3 peripherals. Powered by an external power source, this clock and register data are expected to survive any power event, the CPU being reset, halted or powered off, while happily continuing to count the progress of time until the rest of the MCU and its firmware returns to check up on its progress.
Naturally, this continuation requires two things: the first is a power source to the special power pin on the MCU (VBAT), often provided from a ubiquitous 3 V lithium cell, along with a clock source that remains powered when the rest of the MCU isn’t. This provides the first gotcha as the RTC clock can be configured to be one of these three:
  • Low Speed External (LSE): usually an external 32,768 Hz oscillator which is powered via VBAT.
  • Low Speed Internal (LSI): a simple internal ~40-ish kHz oscillator that is only powered by VDD.
  • High Speed External (HSE): the external clock signal that’s generally used to clock the MCU’s CPU and many of its peripherals. Also not available in all low-power modes.
Thus, the logical RTCCLK choice for an RTC that has to survive any and all adverse power events is the LSE as it feeds into the RTC. Take for example the STM32F103 RTC block diagram:
Simplified RTC diagram of the STM32F103. (Source: RM0008)
Here we can see the elements of the very basic RTC1 peripheral, with the sections that are powered by VBAT marked in grey. The incoming RTCCLK is used to generate the RTC time base TR_CLK in the RTC prescaler, which increases the value in the RTC_CNT register. It being a 32-bit register and TR_CLK usually being 1 Hz means that this counter can be run for approximately 136 years if we ignore details like leap years, without overflowing.
For initializing and using the RTC1 peripheral, we can consult application note AN2821 alongside reference manual RM0008, which covers a clock and calendar implementation, specifically on the STM3210B-EVAL board, but applicable to all STM32F10x MCUs. If you want to keep a running calendar going, it’s possible to use the backup registers for this whenever the counter reaches a certain number of seconds.
That said, where having just this counter is rather pleasant is when using the C <time.h> functions with Newlib, such as time(). As Newlib on STM32 requires you to implement at least _gettimeofday(), this means that you can just let RTC_CNT do its thing and copy it into the seconds member of a timeval struct before returning it. This is significantly easier than with RTC2 and 3, with my own implementation in Nodate’s RTC code currently fudging things with mktime() to get a basic seconds counter again from the clock and calendar register values.
All The Bells And Whistles
If the RTC1 peripheral was rather basic with just a counter, an alarm and some backup registers, its successor and the rather similar RTC3 peripheral are basically the exact opposite. A good, quick comparison is provided  here, with AN4759 providing a detailed overview, initialization and usage of these newest RTCs. One nice thing about RTC3 is that it adds back an optional counter much like the binary RTC1 counter by extending the RTC_SSR register to 32-bit and using it as a binary counter. However as the summary by Efton notes, this counter and some other features are not present on every MCU, so beware.
Correspondingly, the block diagram for the RTC2 peripheral is rather more complicated:
Block diagram of the RTC 2 peripheral in the STM32F401 MCU. (Source: ST, RM0368)
Although we can still see the prescaler and backup/tamper registers, the prescaler is significantly more complex with added calibration options, the alarms span more registers and there are now three shadow registers for the time, date and sub-seconds in RTC_TR, RTC_DR and RTC_SSR respectively. This is practically identical to the RTC3 block diagram.
These shadow registers lay out the individual values as for example in the RTC_TR register:
The RTC_TR register in the STM32F401. (Source: ST, RM0368)
Taking the seconds as an example, we got the tens (ST) and units (SU), both in BCD format which together form the current number of seconds. For the minutes and hours the same pattern is used, with PM keeping track of whether it’s AM or PM if 12 hour format is used. Effectively this makes these shadow registers a direct source of time and calendar information, albeit generally in BCD format and unlike with the basic RTC1 peripheral, using it as the source for C-style functions via Newlib has become rather tricky.
Unix Time Things
In the world of computing the ‘seconds since the Unix Epoch’ thing has become rather defining as the starting point for many timing-related functions. One consequence of this is that indicating a point in time often involves listing the number of seconds since said epoch on January 1st of 1970, at 00:00:00 UTC. This includes the time-related functions in the standard C libraries, such as Newlib, as discussed earlier.
This is perhaps the most frustrating point with these three-ish different STM32 RTC peripherals, as although the RTC1 is barebones, making it work with Newlib is a snap, while RTC2 and RTC3 are for the most part a nightmare, except for the RTC3 implementations that support the binary mode, although even that is a down-counter instead of an up-counter. This leaves one with the dreadful task of turning those shadow register values back into a Unix timestamp.
One way to do this is by using the mktime() function as mentioned earlier. This takes a tm struct whose fields define the elements of a date, e.g. for seconds:
tm tt;
tt.tm_sec = (uint8_t) bcd2dec32(RTC_TR & (RTC_TR_ST | RTC_TR_SU));
By repeating this for each part of RTC_TR and RTC_DR, we end up with a filled in struct that we can pass to mktime which will then spit out our coveted Unix timestamp in the form of a time_t integer. Of course, that would be far too easy, and thus we run head-first into the problem that mktime is incredibly picky about what it likes, and makes this implementation-dependent.
For example, despite the claims made about ranges for the tm struct, running a simple local test case in an MSYS2 environment indicated that negative years since 1970 wasn’t allowed, so that not having the RTC set to a current-ish date will always error out when the year is less than 71. It’s quite possible that a custom alternative to mktime will be less headache-inducing here.
Of course, ST could just have been nice and offered the basic counter of RTC1 along with all of the good stuff added with RTC2 and RTC3, but maybe for that we’ll have to count the seconds until the release of RTC4.
8 thoughts on “Bare Metal STM32: The Various Real Time Clock Flavors
  1. Considering neither the application note nor the reference manual for the STM32F1xx mention anything about RTC_CNTH/RTC_CNTL being BCD, I’ll take a wild guess that you’ve never tested your code for more than 18 hours.
  2. Yes, so true. RTC2 and RTC3 are a pain to work with in every meaningful environment – namely newlib.
    Also, who thought it would be a wise idea to offload something as fragile (look at how often the fr..cking timezone database is updated!) as a calendar (a calendar! as if there was only one calendar in this world!) into solid silicon? And then not even provide the raw counter, for god’s sake.
    1. FWIW there are applications (toys and things that only care about recurring weekly schedules) where people don’t care about time zone handling and they use whatever time handling that’s readily available instead of sticking with the standard library.
      1. But… just.. why would one want to do that? On a modern 32bit ARM? Hooking up the RTC1 counter to newlib is a no-brainer in 10 LOC and it provides me with all the standard date/time routines that have been there for decades.
        Using the hardware calendar of RTC2/3 requires me to dig through many pages of reference manual and (in the case of STM, unfortunately more than often only briefly documented) registers, possibly think through corner cases and oddities, likely some errata and so on. With the added benefit of writing absolutely non-portable code. Oh, my.
        1. Maybe they were migrating from a different project with a PCF8523 or similar and already have code for handling individual date/time fields. But yeah, for new stuff, best to just use what works with the standard C library.
  3. I love the powerful hardware timers of traditional MCUs so much. I recently had to use nRF52840 for a project (several actually), and the hardware is just…not very advanced. I know their whole point is IoT and connectivity but its still my personal pet peeve. I like depending on hardware timers, prescalers and the ability to chain them, DMA, ADC etc everything together to free up CPU
Leave a Reply to SureItsBCD?Cancel reply
