When Low SRAM Keeps The DOOM Off Your Vape
The PIXO Aspire is a roughly $35 USD vape that can almost play DOOM, with [Aaron Christophel] finding that the only thing that realistically stops it from doing so is that the Cortex-M4-based Puya PY32F403XC MCU only has 64 kB of SRAM. CPU-wise it would be more than capable, with a roomy 16 MB of external SPI Flash and a 323×173 pixel LC touch screen display covering the other needs. It even has a vibration motor to give you some force feedback. Interestingly, this vape has a Bluetooth Low-Energy chip built-in, but this does not seem to be used by the original Aspire firmware.
What [Aaron] did to still get some DOOM vapors on the device was to implement a screenshare firmware, allowing a PC to use the device as a secondary display via its USB interface. This way you can use the regular PC mouse and keyboard inputs to play DOOM, while squinting at the small screen.
Although not as completely overpowered as a recent Anker charging station that [Aaron] played DOOM on, we fully expect vapes in a few years to be perfectly usable for some casual gaming, with this potentially even becoming an original manufacturer’s function, if it isn’t already.
27 thoughts on “When Low SRAM Keeps The DOOM Off Your Vape
      1. Some ones you can get in AUS already do that, they don’t network but just have a bunch of preloaded ads, just selling more vapes though. They let you put your own image on it if you get the app (which probably does network/update it with anything at that point)
        Needless to say, I didn’t buy/use or do any of that but my friend has a bunch of them lying around I’ve been wanting to mess with. Everything but the display module is single use but you can only buy both together lol.
    1. Because they can. I expect the BOM to come out to an equal price, and someone in marketing wanted colors and that newfangled multimedia that’s all the rage now.
      As the device uses pods and hence isn’t single-use you can have at least some fun with the holder itself.
    2. The Puya chips are probably very nearly as cheap as the OTP 8 bitters these days and they really are overkill, especially with unused Bluetooth and the screen but, weirdly, I think it might actually have a positive effect on the e-waste problem because the screen etc adds perceived value to a product which might just mean people hang on to them longer.
  1. If the LCD controller is ST7789 (I probably missed that detail) supporting 320x240x18 bit, there’s an extra 50 kB available through RAMWRC, RAMRDC commands, and perhaps some more when dropping to 8 bit or monochrome.
  2. I think this lends itself to use as a prop for a dystopian movie.
    An asthma inhaler that only gives a puff or two before a character pops up on screen wanting your credit card number.
    That or a Trek style isolinear chip.
    Plug in into a row of receptacles.
    Plug into one socket, it shows an image of someone’s soul that has been captured.
    Remove it and vape…as the vape dissipates, the image on the screen seems pulled towards the mouthpiece.
    Sound of screaming added in post.
  3. Interestingly, this vape has a Bluetooth Low-Energy chip built-in, but this does not seem to be used by the original Aspire firmware.
    Am I the only one who thinks this is crazy? Cortex M4 with FPU and DSP features and a colour LCD wasn’t enough, they put a BLE chip but didn’t even bother using it…
    And my boss tells me we can’t put a reverse polarity diode because the BoM is already too expensive
    1. Most of the disposable vapes that have “xl” capacity have a screen now, some have more than one. Some of the info on it is charge, puffs etc.. but they also usually have an animation (often of space, oddly) when you draw. My coworker smokes them constantly and I’ve torn a few apart to salvage batteries.
Leave a Reply to jonkangasJonCancel reply
