Decorate Your Neck With The First Z80 Badge
Over the years, we’ve brought you many stories of the creative artwork behind electronic event badges, but today we may have a first for you. [Spencer] thinks nobody before him has made a badge powered by a Z80, and we believe he may be right. He’s the originator of the RC2014 Z80-based retrocomputer, and the badge in question comes from the recent RC2014 Assembly.
Fulfilling the function of something you can write your name on is a PCB shaped like an RC2014 module, with LEDs on all the signal lines. It could almost function as a crude logic analyser for the system, were the clock speed not far too high to see anything. To fix this, [Spencer]’s badge packs a single-board RC2014 Micro with a specially slow clock, and Z80 code to step through all memory addresses, resulting in a fine set of blinkenlights.
Thus was created the first Z80-based event badge, and we’re wondering whether or not it will be the last. If you’re curious what this RC2014 thing is about, we reviewed the RC2014 Micro when it came out.
4 thoughts on “Decorate Your Neck With The First Z80 Badge
  1. Oh no you don’t. I just happened to come across a tube of Z80’s and another with 8051’s the other day. I’ve got enough going with ESP32 projects and you’re not going to get me interested in going back to working on 8 bit microprocessors (Well at least not now). Did a bunch of them back in the day and it was quite a hoot…..Keep going, it looks like fun.
    Cheers.
Leave a Reply to LIV2Cancel reply
