When it comes to microphones, [Roan] has expensive tastes. He fancies the famous Telefunken U-47, but doesn’t quite have the five-figure budget to afford a real one. Thus, he set about getting as close as he possibly could with a build of his own.
[Roan] was inspired by [Jim Lill], who is notable for demonstrating that the capsule used in a mic has probably the greatest effect on its sound overall compared to trivialities like the housing or the grille. Thus, [Roan’s] build is based around a 3U Audio M7 capsule. It’s a large diaphragm condenser capsule that is well regarded for its beautiful sound, and can be had for just a few hundred dollars. [Roan] then purchased a big metal lookalike mic housing that would hold the capsule and all the necessary electronics to make it work. The electronics itself would be harvested from an old ADK microphone, with some challenges faced due to its sturdy construction. When the tube-based amplifier circuit was zip-tied into its new housing along with the fancy mic capsule, everything worked! Things worked even better when [Roan] realized an error in wiring and got the backplate voltage going where it was supposed to go. Some further tweaks to the tube and capacitors further helped dial in the sound.
If you’ve got an old mic you can scrap for parts and a new capsule you’re dying to use, you might pursue a build like [Roan’s]. Or, you could go wilder and try building your own ribbon mic with a gum wrapper. Video after the break.
[Thanks to Keith Olson for the tip!]
What a f*** dumb idea to thermally insulate the tube.
Heck, tubes produce a lot of heat that needs to be dissipated.
I worked on tube based elctronics many years. Never I have sean a dumb construction like this.
Tubes even need FORCED air flow in some times.
He eventually didn’t thermally insulate the tube, see the video.
Hey he says right from the start that he doesn’t know what he’s doing
I Would like to see Your Videos on Doing It Better . Please include the vendors of the parts and cost of the parts . I think this is a great idea for someone who can’t afford the high end prices but won’t that high end performance . Please leave link to your videos here . Thank You .
“It looks just like a Telefunken U47. You’ll love it.”
One of my favourite mics, however it has a different name where I come from.
Wikipedia says “Units produced before 1950 were distributed by Telefunken and bear the Telefunken logo.”
https://en.wikipedia.org/wiki/Neumann_U_47
Next hack, figuring out how to build average Sam’s car for under $6K using the same parts used to build a $65K one.
It’s always a win when you remember to put the heat shrink on before soldering.
Nice.
It’s also quite possible to DIY some very good-sounding mics at a more modest price-point which, while not at the esoteric levels of a tube U-47, are still very respectable and more than up to professional use.
https://groups.io/g/MicBuilders/topics
I’m confused. If he started out with N microphones did he end up with
N,
N-1,
N+1,
N-2, or some other number of microphones?
Actually if I wanted you to build one for me what would be the overall cost . Great vocals at the end there .
