The Cardboard Airplane Saga Continues
History is full of engineers making (or attempting to make) things out of the wrong stuff, from massive wooden aircraft to boats made of ice and sawdust. [PeterSripol] is attempting to make an ultralight aircraft out of a rather wrong material: cardboard. In the previous installment of the project, a pair of wings was fabricated. In this installment, the wings find their home on an equally mostly cardboard fuselage, complete with rudder and elevator.
The fuselage construction amounts to little more than a cardboard box in the shape of an RC airplane. Doublers provide additional strength in critical areas, and fillets provide a modicum of additional strength around seams. To support the weight of the pilot, a piece of corrugated cardboard is corrugated again, with an additional piece making up the floor. With the addition of a couple of side windows for comfort and visibility, the fuselage is completed, but additional components need to be added.
The most difficult challenge in making the fuselage is, in part, unrelated to the building material of choice. To allow the aircraft to be transported to the show after it’s built, the wings are detachable. Detachable wings would be no big deal on a normally constructed ultralight, and permanently affixed wings would be no big deal on a cardboard aircraft, but the combination of the two poses structural integrity challenges. As such, some plywood and aluminum are used to provide the strength needed.
The horizontal and vertical stabilizer construction is fairly simple, with cardboard folded over ribs creating a rather strong surface. At the ends of each are mounted the elevator and rudder, with fiberglass tape making up the hinge. Finally, the tail is mounted to the airframe using a couple of wood screws and some rope.
Despite the questionable choice in materials, the aircraft appears to be reasonably strong, and we love seeing things used in ways they were never intended. Make sure to stay tuned for more coverage, and while you wait, read our write-up on the previous installment of the project!
25 thoughts on “The Cardboard Airplane Saga Continues
  1. Again?
    I’ll quote some comment from the previous installment:
    “More YouTube algorithm food…
    You HAVE to stop highlighting this trash.”
    One of the most useful cardboard plane applications I’ve seen lately are the SYPAQ ones sent to Ukraine from Australia.
    1. Who cares if its really useful when it is fun, or being done for the challenge?!?!
      Not my favourite thing to watch either as a rule, but overcoming limited materials and a rulebook you must adhere to so it remains an ultralight is an interesting challenge. Or for a different example of because you can fun/challenge I really enjoyed recently look at “Building a Bimetallic Tea Monitoring Mechanism” video from Chronova Engineering – it is an absolutely daft solution, but wonderfully executed.
      Also Peter has done some real testing of the construction methods and wing loading etc that could actually be useful to you and any of us too! Seeing how and when the layers of card actually fail in those test beams in the real world I expect will be worth having in the back of your head, no hugely shocking results (at least to me) but it does give a good benchmark for how good cardboard really can be.
    2. Also if you are interested in cardboard drones for Ukraine or at least their utility, which is worth thinking about consider how the methods used here may actually be useful for larger scale but very cheap disposable drones. This is a rather huge aircraft to be all cardboard, and at least is meant to hold a person, which is a heck of a alot of mass, and construction wise rather quick and easy if you can access a laser cutter to turn waste into wing spar etc…
    3. Normally I’d agree but this is Peter Sripol. He’s a pilot and has built 4 other ultralights from scratch and flown them. He’s also built many RC aircraft out of cardboard so this is just a larger scale project. Watch some of the other videos in his channel and you’ll see he is definitely a hacker.
    1. Kinda. The 2-33 is the two seat trainer and the 1-26 is the one seater. I have a bunch of hours in both and they are really, really fun aircraft. Super light wing loading and on light lift days sometimes then only gliders that stay up when everyone else has to land. That’s satisfying.
      They are made out of tube steel though. Wings are aluminum skinned and a lot of the other stuff is fabric.
      As an aside if this highlighted project is indeed a glider and not a powered aircraft cardboard is about the worst thing I could think of other than toilet tissue. Gliders fly in thermals and stuff and the occasional shower happens sometimes. Might as well be wet tissue at that point.
  2. Didn’t watch video.
    Is this in CONUS ?
    If so, good luck convincing the local FAA FSDO that it complies with
    “accepted aeronautical standards and practices”. No way would I (if
    I were the inspector), “sign off” this testimonial to a rejected pitch for
    Myth Busters.
    And, don’t forget the 8130-12
    1. I understand saying “CONUS” can make someone feel supersomething but pretty sure the FAA has jurisdiction in but not limited to Alaska, Hawaii, and Puerto Rico.
      On the old gameshow I’ve Got a Secret there was a guy who built a boat out of cardboard and used it to cruise “CONUS” ‘s Intracoastal Waterway.
  3. I wonder why mr Guthrie thinks wood is a bad material to make airplanes out of.
    Is he trying to diss the spruce goose?
    Also I don’t understand the dislike for ships made of pykretre.
  4. Otto Lilienthal would be proud, btw.
    Otto Lilienthal, one name thrown out of the US world history lessons, mostly trumpled – pun intended – by Write Brothers. Though, I suspect this is the direct result of the ongoing collective/widespread self-induced post-WWII US amnesia, that arbitrarily removed any german-sounding names. (Graff Hindenburg stayed, but mostly because it was attached to the spectacular disaster of the dirigible with the same name, but the rest of important names were just thrown out, or reduced in importance – say, everyone in the US knows who al gore or bill gates are, but few can tell why James Maxwell – the physicist, not the actor – or Michael Faraday discoveries were important).
  5. Very interesting build. I also have studied and applied many of Peter’s concepts. Found some of his methods are not as effective as others but that’s the learning curve we all go through no disrespect to Peter. One mentioned build idea someone had posted on his phone was to use “triangle beam method” lot stronger than traditional “box” beam. I have applied this to some discovery projects and found this to be an exceptional method. Hope to do a short U Tube video myself here soon, Peter, you just beat me to it ha ha.
    Looking forward to your completed project.
    Good luck be safe.
Leave a Reply to ialonepossessthetruthCancel reply
