DIY Light Panels Work With Home Assistant
There are a few major companies out there building colorful LED panels you can stick on your wall for aesthetic purposes. Most commercial options are pretty expensive, and come with certain limitations in how they can be controlled. [Smart Solutions For Home] has whipped up a flexible DIY design for decorating your walls with light that is altogether more customizable.
In this case, the DIY light panels ape the hexagonal design made popular by brands like Nanoleaf. In this case, each hexagon panel runs an ESP32 microcontroller, which controls a series of WS2812 addressable LEDs. This allows each panel to glow whatever color you like, and they’re arranged in an XY grid to enable you to light individual panels with a range of different geometric effects. The benefit of having a full microcontroller on each panel is that they can act quite independently—each one able to be used as a smart light, an notification display, or even as a physical button, all integrated with Home Assistant.
If you’re a fan of DIY smart home products, these might be right up your alley. They’re supremely flexible and customizable, and can do a lot of things that commercial versions can’t easily replicate. Just don’t ignore the fact that they require a considerable amount of assembly, what with the custom PCBs, 3D printed enclosures, and front diffusers to deal with. That’s just the way the LED wall crumbles.
We’ve seen other similar builds before, too. Why? The simple fact is that a lot of people want cool glowy panels on their wall without having to pay through the nose for them.
2 thoughts on “DIY Light Panels Work With Home Assistant
  1. You can basically take every nanoleaf clone, add one esp32/8266, and run that with wled.
    I have two of these setups running, one with 9 elements about the size of nanoleafs, one with 74 elements about 1/4th of the size of one nanoleaf element. These were both also pretty cheap in comparison to nanoleafs.
    The easiest way is ofc to just use a 3d printer and do it completely by yourself.
    I can see though that maybe this setup is able to do even more than wled can, but wled is already a powerhouse, and fully integrated into HomeAssistant.
Leave a Reply to eponraCancel reply
