Amiibo Emulator Becomes Pocket 2.4 GHz Spectrum Analyzer
As technology marches on, gear that once required expensive lab equipment is now showing up in devices you can buy for less than a nice dinner. A case in point: those tiny displays originally sold as Nintendo amiibo emulators. Thanks to [ATC1441], one of these pocket-sized gadgets has been transformed into 2.4 GHz spectrum analyzer.
These emulators are built around the Nordic nRF52832 SoC, the same chip found in tons of low-power Bluetooth devices, and most versions come with either a small LCD or OLED screen plus a coin cell or rechargeable LiPo. Because they all share the same core silicon, [ATC1441]’s hack works across a wide range of models. Don’t expect lab-grade performance; the analyzer only covers the range the Bluetooth chip inside supports. But that’s exactly where Wi-Fi, Bluetooth, Zigbee, and a dozen other protocols fight for bandwidth, so it’s perfect for spotting crowded channels and picking the least congested one.
Flashing the custom firmware is dead simple: put the device into DFU mode, drag over the .zip file, and you’re done. All the files, instructions, and source are up on [ATC1441]’s PixlAnlyzer GitHub repo. Check out some of the other amiibo hacks we’ve featured as well.
One thought on “Amiibo Emulator Becomes Pocket 2.4 GHz Spectrum Analyzer
  1. I’m intrigued. I didn’t know know that Amiibo emulators were a thing. So Pixl.js is a battery-powdered nRF52832 doohicky, Nintendo homebrewers turned it into an Amiibo emulator, then ATC1441 made it a spectrum analyzer firmware. Pretty cool for $20 hardware
Leave a Reply to MaaveCancel reply
