Do you like hacking? Do you like apple cider? Do you like ceiling fans? If you answered “yes” to any of those questions, then boy do we have the project for you! [Lou Wozniak] has an awesome tutorial for building an apple cider press using a ceiling fan motor and a handful of items available at your local hardware store.
The build is pretty simple in concept but complex in execution, and [Lou] does a fantastic job of covering every step in detail in his two project videos. The project has two main components: the grinder to decimate the apples and create a juicy, pulpy soup, and the press to extract the juice. The grinder is powered by the fan motor, while the press uses a screw-drive connected to a power drill, and then a ratchet to squeeze out every last drop.
Eager for more ceiling fan motor goodness? You’re in luck! Apparently [Lou] is a master of repurposing fan motors, and we featured a pottery wheel he made with one a while back.
Continue reading “Apple Cider Press Is Just In Time For Fall”
