[Everett] is at it again with Prometheus, an arm mounted flame thrower.This is the third generation of the project and makes some huge advances over the second generation we saw last year. We’d say he’s reached cinema/stage-performance quality with his design.
The self-contained system is completely arm mounted with a fuel reservoir mounting behind the elbow. The new version adds an adjustable flow valve actuated by a servo motor to regulate the flame size. An arc generator has been incorporated to replace the lighter from the last version. A microcontroller measures wrist angle and takes care of creating the arc and regulating the fuel supply.
Prometheus is small, controllable, and frightening. See a full demonstration as well as some video of the prototyping process after the break. Does this make you wonder how much burn cream [Evertt’s] needed over the years?
