Watch That Sound: Your Own Chladni Plate
What if you could see sound? A Chladni plate uses a speaker and small particles, like sand, to give you a visual representation of sound, and [CrazyScience] shows you how to make one. The plate dates back to 1787, created by the eponymous physicist. Of course, back then, there were no speakers, so the original plate was metal with a violin bow raked across the edges.
The modern version uses an ESP32, a speaker, and salt. The patterns depend on the resonance points of the plate. The device has a rotary encoder to tune different frequencies. Check it out in the video below.
Continue reading “Watch That Sound: Your Own Chladni Plate” →
