Perhaps your taste for pizza has never taken you beyond your local fast-food chain or a frozen pizza from the supermarket, but there are some people for whom only the most authentic will do. A wood-fired clay oven and nothing less is their pre-requisite, and lesser methods of pizza preparation simply aren’t good enough.
[Jan] is one of these pizza perfectionists, and his wood-fired oven is an interesting one because it eschews the traditional dome for a cylinder. His very detailed write-up gives us an interesting insight into its construction. He’s taken the bottom half of an oil drum as his base, and built and fired the clay oven itself around a wooden former. We see his early attempts at a former which distorted under the weight of clay, and we hear about how the clay required reinforcement with chicken wire and straw. Finally, we see the structure being dried out, before an impressive display when firing for the first time. The oven receives a coat of Rockwool insulation but [Jan] has a way to go to learn the oven’s characteristics. Still, this is an oven that will last to refine the perfect morsel given a bit of time.
We like the cylindrical design as an alternative to domed ovens, which can be a bit tricky to build. An oven may be a bit low-tech compared to some of Hackaday’s usual fare, but they can be no less difficult to get right. We’re no stranger to novel flame-based cookery, perhaps you might like to also take a look at this rocket grill.
