The Raspberry Pi B+ has a native VGA connection. Sure, it’s hidden away in binary blobs and device trees, and you need to wire up the GPIO pins just right, but it’s possible to connect a VGA monitor to a Raspi B+ natively. For the brave, smart, or foolish, this means you can also drive raw DPI displays. [Robert] had a few of these dirt cheap displays sitting around and decided to give the entire thing a go. It worked, and he’s written down how to do it.
One of the chip architects for the Raspberry Pi, [Gert van Loo], was exceedingly clever when designing the Pi. There’s a parallel interface in the chip that, when combined with a few dozen resistors, can drive a VGA display in addition to the HDMI display. Screens with a Display Parallel Interface are actually pretty similar to what the VGA spec calls for. The problem is, hardly any of this is documented for the Raspberry Pi, and finding it means trawling through forums.
[Robert]’s example circuit uses a 5″ display from Adafruit, a 40-pin breakout, and a bunch of prototyping wires. Setup requires grabbing a cut down version of the device tree used for the Raspi VGA breakout board, setting the output format, rgb order, and aspect ratio of the display, and wiring everything up.
What’s interesting here is that [Robert] reproduced this project from scratch, and found that any display with a 40-pin DPI connector will work with the Raspi, provided you have a datasheet. That’s pretty cool; these displays can be cheap, and since we don’t yet have a proper DSI display for the Pi, this will have to do for now.
Video below of [Robert]’s inspiration for this build, [Ladyada].
Continue reading “Using Cheap Displays With The Raspberry Pi”
