CRTs are the king of displays for any homebrew project. They have everything – high voltages, high vacuums, X-rays, and the potential for a vector display – that makes a project exude cool. Getting an old CRT up and running, though, that’s another story. Never rear, because now there’s an Open Hardware eletrostatic CRT driver for your next display.
[Eric] designed a driver circuit that should be able to send a picture to most 2″, 3″ and some 5″ electrostatic CRTs, the kind found in ancient TVs and oscilloscopes. The 1kV power supply uses a transformer usually found in a CCFL bulb, and is able to produce several milliamps. You’ll want to keep one hand behind your back when working on this.
The driver circuit takes a 0-3.3V analog signal for deflecting the beam along the X and Y axis. The amplifier has enough bandwidth to handle NTSC video, so displaying video along with vector letters and shapes is also a possibility with this circuit. Most of the files are available on the git, with three boards available to be ordered from OSHPark.
Thanks [Mike] for the tip.
