Cats are great to have around, but they need exercise. If you’re not in a position to let the cat outdoors, you need to look to something else when kitty wakes up bored from her 23 hour nap. Cat playscapes are useful diversions, but this is the first time we’ve considered real exercise equipment. Let’s get our feline friends their exercise fix with a hamster-esque cat exercise wheel.
[bbarlowski]’s design is simple but very clever, and almost looks like something you’d find flat-packed at IKEA. Built of CNC-milled birch plywood, the wheel rims snap together like puzzle pieces while the floor has tabs that slot into the rims. The tension of the bent floor panels locks everything together and makes for a smart looking wheel. The video after the break shows [Kuna the Maine Coon cat] in action on the wheel, and outlines a few plans for expansion, including adding an Arduino to monitor kitty’s activity and control both an RGB LED strip for mood lighting and a cat treat dispenser for positive reinforcement of the exercise regimen.
The project mounted an unsuccessful campaign in March and they’ve made the DXF cutting files available for download. Of course if it’s too much plywood and not enough Arduino for you, just build the Arduspider to torture – err, entertain your cat.
