Word clocks – time pieces that spell out the current time with words – are awesome. They’re usually entirely electronic, illuminating LEDs to display the time. Not this one. It’s a mechanical masterpiece that shows the current time in words using motors and 35mm film leader.
The mechanics of this clock are fairly simple: text is transferred onto 35mm film leaders with water slide decals, which are then rolled onto film reels. These film reels are mounted on stepper motors attached to a frame with Meccano. There are four film strips, making this a surprisingly similar a word clock but using motors instead of LEDs.
Because this clock was originally built in 2008, the electronics are a bit… strange through the lens of a post-Arduino skill set. [David] is using a homebrew BASIC Stamp with eight Step Genie ICs and MOSFETs for each motor. Calibration of the clock is handled by an IR detector and a mark on each piece of film leader.
It’s an impressive example of mashing up spare and surplus parts to make something cool, but unfortunately we can’t find a video of this clock in action. If you manage to find one, put a link in the comments and we’ll add it below.
