Halloween Prop: DIY Fog Machine
diy-fog-machine
Reader [Daniel] told us about a video detailing how to make your own fog machine. This project uses two disposable roasting pans to create a fog chamber. Inside you will find an upside-down clothes iron to convert fog liquid into a gas. The liquid is gravity-fed from a water-bottle reservoir on top, converted to smoke by the hot iron, then the newly created smoke is directed out of the chamber by a 12 volt fan.
You probably have an old iron sitting around (especially if you use the toner transfer method for making PCBs), as well as a fan of some type. The build method used in the video is not at the level we usually look for. Using one blade of a pair of scissors is not what we recommend for stripping wire insulation. We also don’t advocate hot gluing a wire to a battery for a reliable connection (for that you’d want wire glue). But with better building techniques, and perhaps an air intake fan for better fog direction, this has potential.
The project is predicated on the availability of “fog juice”. We’re probably not going to head out and buy a bottle of that so look into making some yourself from glycerin and demineralized water.
