There’s many a hacker that considers coffee a necessary fuel, without which, little work can be achieved. This applies whether in the office or traipsing around in the great outdoors. For the latter situation, [Poehls05] developed a robust French press that’s well suited to field use.
Typically, a French press consists of a plunger assembly which moves within a glass vessel. This is fragile and unwieldy for throwing in a backpack. Instead, in this design, the plunger assembly is harvested from an existing press and repurposed to fit within a sturdy Nalgene water bottle, designed specifically for overlanding.
The modifications involve cutting the existing press plate into three slices, and reassembling with hinges so it may fold. The plunger rod is then modified to make it possible to tilt the press plate relative to the rod. These modifications allow the plunger to be slid into the narrower neck of the Nalgene water bottle, and also enable the plunger rod to work with the original screw-down lid. In this configuration, the bottle is no longer water tight, but can be converted to normal use by swapping a regular lid back on top.
With the changes in place, the plastic bottle can easily be used in the same manner as a regular French press. Simply fill with hot water, allow the grounds to steep, and then press and pour. It’s a great way to make high-quality coffee in the wilderness, and one that may prove popular with hackers who don’t wish to give up the finer things when out and about. We’ve also featured tricks to make the most of hotel coffee, too.
