[Gary Honis] has been modifying his Canon Digital Rebel XSi in order to do astrophotography. He previously removed the IR filter and replaced it with a Baader UV-IR cut filter that lets most infrared light through. However, in order to reduce noise in the pictures, he had to cool the camera down. He based the project on a peltier cooler that he salvaged from a powered beverage cooler. He made a small aluminum box and insulated it with styrofoam to hold the camera body. The peltier cooler was then attached on the side. It takes just over an hour to cool the camera down to 40 degrees, but the shots come out a lot clearer.
[thanks adam]
