The Global Village Construction Set is an open hardware initiative aimed at sharing tool-building knowledge. They believe that to build civilization you need forty basic tools, eight of which they’ve already prototyped and made available on their wiki. Included in these is a tractor which reminds us of a beefy bobcat. It has a soil pulverizing attachment which can be used to break down soil and feed it to their soil brick compressor. That machine spits out compressed dirt bricks which are used as building materials. They’re stacked on concrete footings and then limewashed to protect the un-baked bricks from water erosion. Does this remind anyone else of real-life Minecraft?
Above you can see a group of Open Source Ecology developers showing off bricks in front of the machine that made them, with the tractor/soil pulverizer to the right. Take a look at the videos about the construction set and brickmaking after the break. And learn more by perusing their weblog.
If you think an apocalypse is on the way you might want to buddy-up with these folks. They seem to know what they’re doing.
