This is a mod more than a hack but any time you can alter original equipment to maintain its usability is a win-win scenario for you and the environment. Everyone has or knows somebody that has a vehicle and most vehicles nowadays have some type of hatchback or hood where the support solution is gas filled struts. Inevitably these gas filled struts fail with age and the failure is accelerated in hotter or colder climates. If you ever had to replace these items you know they can cost a minimum of $20 to as much as $60 a piece. Most vehicles require two, four or even eight of these costly little devices.
[Brian] from Briansmobile1 YouTube channel documented three simple and low cost solutions. We all probably know of the vice clamp solution but that is cumbersome and still an expensive solution which is not always very handy or fast. Another solution is to cut a piece of rubber hose in a kind of special way so it is easy to put on and take off the shaft and dangles from a string so it’s always available. The best solution was to use a hitch pin also connected to a string or wire. To make the hitch pin work you have to grind a couple of notches on either side of the lift shaft at just the right spot so the pin can be snapped on and prevent the shaft from retracting at your selected height.
We are sure these solutions will come in handy at some time in most everyone’s driving career. Just after the break we will link to all three of [Brian’s] handy videos on gas strut fix solutions. And if you do your own automotive repair we can definitely recommend [Brian’s] channel of over 600 vehicle repair and maintenance videos which normally come with a dose of philosophy and humor.
Continue reading “3 Cheap Hood/Hatchback/Topper Mods To Save Your Noggin”
