This Week In Security: Baked-in Malware, Freezers Not Freezing, Zoom Snoops Clipboards, And AI Makes Things Worse, Faster
The AI platform ServiceNow which offers both hosted and on-premises versions just patched a trifecta of CVSS-10 vulnerabilities.
CVSS rankings are determined by the severity of a flaw, the ease of exploiting the bug, if authentication is required for exploitation, if the vulnerability exposes confidential data, and other criteria. A CVSS of 10 is as bad as it gets, and having three of them at once is certainly attention-getting. Of the three vulnerabilities fixed, one allowed unauthenticated modification of data in the hosted instance, a second allowed arbitrary code execution via the GraphQL interface, and the third allowed arbitrary SQL commands that could modify the database.
ServiceNow claims Adobe, Lenovo, Fedex, and Fujitsu among their high-profile customers. With luck, the vulnerabilities were patched before significant public exploitation could happen.
Router Malware
Previously in 2026 the US Government warned against embedded malware found in consumer routers, which may be linked to the FCC enacting bans against certification and import of foreign-made consumer devices. This week, the NVD (National Vulnerability Database) reported specific embedded malware in the Zbtlink and MoreQuick brands of devices.
Multiple versions of the firmware, for multiple lines of products, contain a backdoor service that uses unencrypted UDP to connect to a command and control (C2) service. The service, or anyone able to intercept the network traffic, since it’s unencrypted, can execute commands as root, allowing them to change configurations, open tunnels, or steal ISP credentials.
The malware is baked into the firmware, so removing it is impossible for most users: a factory reset wouldn’t do. In theory if third-party firmware like OpenWRT supports these devices, the hardware could be made safer with a custom install.
Given how commonly the same device is marketed under dozens of names, likely the same devices and firmware have yet to be identified under other brands.
Vulnerability in Qubes
The security-focused distribution Qubes has an important security bulletin for recently discovered issues.
Qubes is built on top of the Xen virtualization system, where each application can be given a dedicated container. The utility to copy files from the primary container into an application container, qvm-copy-to-vm, displays a message if there is an error copying the file. To show the message, the utility launches kdialog with the error as arguments, but fails to ensure that the error doesn’t include shell commands.
The system call used to show the alerts has the dangerous side effect of calling the command as if it was a normal shell. This is extremely powerful, but equally risky: a shell typically allows multiple commands per lines, require quoted strings to protect arguments with spaces or complex text, and can expand variables. Generating an error that escapes out of the message and runs arbitrary commands was all it took.
Qubes already has a fix ready and everyone getting standard updates should have it waiting.
Were US Military Freezers Hacked?
The controls for the freezers used in the commissaries of a growing number of US military bases may have been compromised.
Independent researchers noticed growing reports in Reddit threads that freezer units were out of service, with other service members and families reporting the same. At least fourteen bases throughout the United States appear impacted, and the story has been picked up by the official military newspaper “Stars and Stripes” as well as by mainstream media outlets.
Posts by staff at the bases clarify that it was not a power loss or cooling loss, the fridges and freezers were placed in defrost mode where they self-heated. The commissaries are operated by the Defense Commissary Agency, with central monitoring and control of facilities. Central monitoring makes complete sense when you need to ensure devices are keeping food at a safe temperature, but something definitely seems to have gone wrong.
Diving into it further, M. Elizabeth finds a post from August 9, 2026 describing vulnerabilities in the Danfoss controllers that allow unauthorized access to the refrigeration controller, and a second paper by the same team exposing over 20 vulnerabilities in Copeland refrigeration controllers that included full control of the unit settings. M. Elizabeth is careful to point out that without confirmation from the commissary agency, it’s impossible to know for sure that this was a hack of the control system, but the evidence is mounting.
BGP and SSL Hijack Used to Push Bad Updates
Virtualizor, a web interface for managing virtual machines in an enterprise (bring-your-own AWS), was recently targeted in a global route hijacking scheme.
Border Gateway Protocol (BGP) is a core routing system underlying the Internet at large. Service providers use BGP to announce the ranges of IP addresses they handle and how to reach them. BGP is operated as basically a global gentleman’s agreement: the protocol itself lacks any authentication or encryption. If you think this sounds vulnerable to disruption, you’d be completely right.
Global disruptions have happened accidentally, like when an ISP in Pakistan took down YouTube, deliberately, such as when thieves hijacked the routes to cryptocurrency exchanges, and mysteriously, like when China hijacked parts of the Internet repeatedly with no explanation.
This time, the BGP attack targeted the IP range used by Virtualizor, and was combined with spoofed SSL certificates for the Virtualizor servers to push spoofed updates. The BGP announcement was targeted to a specific class C: a relatively small allocation of 253 addresses, similar to what a home network would use. BGP gives precedence to the smallest announcement for an IP range, so all systems that received the spoofed announcement routed those addresses accordingly. The network advertising the false route was based in Romania, though of course they could also be a victim.
With control over the IP range, the attackers were able to generate a certificate via Lets Encrypt, which was sufficient for browsers and the updater to accept the rerouted addresses. The attackers then published a malicious package that appears to install additional services. The company has not provided details about the trojaned update, so it’s not clear what other risks it poses.
Virtualizor does not have a public list of customers, but one has to assume it includes high-profile companies to make such an attack viable. Hijacking BGP is extremely obvious, and isn’t frequently used for such obvious spoofing attacks.
Linux Zoom Steals Clipboard Contents
Simon Tatham, the author of the extremely popular PuTTY SSH client among other projects, posted on Mastodon an interesting observation about the clipboard behavior of recent Zoom clients on Linux.
Relatively recently, some operating systems have added the ability to alert the user when an application access the clipboard. Unfortunately, Linux is not yet one of them, but thanks to other clipboard management tools, Simon noticed that the recent update to Zoom 7.1.5 copies the contents of the clipboard as soon as they change. What happens to the clipboard contents once copied is currently a mystery.
Considering that the clipboard can often contain passwords, authentication tokens, or simply data you might not want to share with Zoom, automatically scraping the contents isn’t what you’d hope for.
Plex Vulnerabilities
The Plex media streaming software sent out an advisory this week warning about security updates for the server and desktop application.
Details are currently thin, with the promise of future details once CVEs have been assigned. For now, make sure you’re on version 1.43.4 or newer. The Plex post has additional directions for updating on platforms that may not have pushed new packages yet.
AI Accelerates Exploit Development
Security company CrowdStrike has released their 2026 report on threats, focusing on the proliferation of AI tools in exploit writing.
CrowdStrike observed that 88% of exploits happened with 48 hours of the proof of concept code being released, crediting AI tools for shortening the adaptation. Typically proof of concept code is designed to demonstrate the vulnerability without providing an immediate mechanism for malicious use, and the window from exploit announcement to wide-spread risk was on the order of weeks. The report notes some vulnerabilities being widely exploited in 20 hours after public disclosure.
The tightening window makes patching even more important, but rapid patching caries the risk of instability when the patches themselves haven’t had extensive testing. Unfortunately there’s no simple solution; faster exploitation via AI tools drives faster patching, often also with AI tools that can introduce more bugs as well.
18 thoughts on “This Week In Security: Baked-in Malware, Freezers Not Freezing, Zoom Snoops Clipboards, And AI Makes Things Worse, Faster”
  1. Will there be a “Freezer Gate”… ugh…
    Just spinning a yarn here, since this is a government run thing. DeCA did have workforce reduction, maybe someone needed to turn off defrost, once a month, as a work around for a firmware bug. They where let go?
    1. One of the places I worked the security guards were instructed to aggressively power off everything in all the buildings that they patrolled. There was a office canteen in one of the buildings and the issues caused by green policies only came to light after staff noticed that small cartons of milk in fridges had become soft cheese every Monday morning. Somehow they avoided causing food poisoning all the staff.
      So I do not see any issues with monitoring freezers and fridges.
  2. Every week I see various sales of mini-PCs with unrecognizable brand names that I assume are cheap Chinese production… ever since the router issues hit the media I’ve wondered if those cheap PCs are pre-compromised too
        1. Lenovo is famous for being caught more than once with spy stuff (for commercial use) in their BIOS that was baked into any install you did.
          And yet no US politician talks about doing anything against Lenovo ever.
          Conclusion: They partnered and now bake in stuff for the US spooks.
          There simply is no other explanation.
          Same with certain popular router makers who were discovered to have baked in backdoors for ‘security services’. But obviously the US authorities don’t call that ‘malware’.
          I wonder what they do call it in internal communications.
      1. AMD has similar functionality in server CPUs
        And it’s all widely documented on intel/AMD’s sites.
        It’s still a concern though.
        It’s funny BTW that is uses an ARM core, so ARM was already on PCs for a long time.
    1. Depends, are we talking about those Google Android based TV boxes, or actual x86 architecture based mini PC’s?
      The former I wouldn’t be surprised if it’s got malware, and unfortunately, often also fiddly to deal with.
      The latter? Lol, lmao. Live Linux USB and wipe the drive clean, and start over with a fresh install.
