Rocking A New Sound For Guitar
We’ve seen inventive sound hacking from [Jeremy Bell] before on Hackaday. You may remember reading a few months ago about how he invented a new way to produce that familiar effect DJs create when scratching records. By clipping samples from cassette tapes and stretching them across a set of short rails, he was able to refashion the audio pickup to glide over the tape at his fingertips. With a clothes pin wrapped in strips of foil teetering over a contact, he had a responsive tactile switch to aid in producing the cutting needed to carve out a beat.
Since then, [Jeremy] has been evolving this same switch concept and testing out new applications for it. The most recent of which he appropriately referrers to as the “Rocker”. With an electric guitar as a starting point, [Jeremy] uses a similar switching technique to bounce back and forth between two audio signals. The first of which being the sound produced in real-time by hammering on the frets of the guitar, and the second channel having a slight delay. By leveraging the glitchy effect created when switching between the two channels he is able to produce a sound all its own.
The prototype seen in his video is table-bound like the early versions of his Scrubboard, yet he’s able to play one-handed with the guitar and demo his device like a cake walk. It’d be fantastic to see this quirkiness and ingenuity taken to the level of his previous hack, leading to a stand-alone add-on for the guitar. Either way, this is yet another great example of sound play:
Continue reading “Rocking A New Sound For Guitar” →
