New Part Day: Small, Cheap, And Good LIDAR Modules
Fully autonomous cars might never pan out, but in the meantime we’re getting some really cool hardware designed for robotic taxicab prototypes. This is the Livox Mid-40 Lidar, a LIDAR module you can put on your car or drone. The best part? It only costs $600 USD.
The Livox Mid-40 and Mid-100 are two modules released by Livox, and the specs are impressive: the Mid-40 is able to scan 100,000 points per second at a detection range of 90 m with objects of 10% reflectivity. The Mid-40 sensor weighs 710 grams and comes in a package that is only 88 mm x 69 mm x 76 mm. The Mid-100 is basically the guts of three Mid-40 sensors stuffed into a larger enclosure, capable of 300,000 points per second, with a FOV of 98.4° by 38.4°.
The use case for these sensors is autonomous cars, (large) drones, search and rescue, and high-precision mapping. These units are a bit too large for a skateboard-sized DIY Robot Car, but a single Livox Mid-40 sensor, pointed downward on a reasonably sized drone could perform aerial mapping
There is one downside to the Livox Mid sensors — while you can buy them direct from the DJI web site, they’re not in production. These sensors are only, ‘Mass-Production ready’. This might be just Livox testing the market before ramping up production, a thinly-veiled press release, or something else entirely. That said, you can now buy a relatively cheap LIDAR module that’s actually really good.
