See Voyager’s 1990 ‘Solar System Family Portrait’ Debut
It’s been just over 48 years since Voyager 1 was launched on September 5, 1977 from Cape Canaveral, originally to study our Solar System’s planets. Voyager 1 would explore Jupiter and Saturn, while its twin Voyager 2 took a slightly different route to ogle other planets. This primary mission for both spacecraft completed in early 1990, with NASA holding a press conference on this momentous achievement.
To celebrate the 48th year of the ongoing missions of Voyager 1 and its twin, NASA JPL is sharing an archive video of this press conference. This was the press conference where Carl Sagan referenced the pinpricks of light visible in some images, including Earth’s Pale Blue Dot, which later would become the essay about this seemingly insignificant pinprick of light being the cradle and so far sole hope for the entirety of human civilization.
For most people in attendance at this press conference in June of 1990 it would likely have seemed preposterous to imagine both spacecraft now nearing their half-century of active service in their post-extended Interstellar Mission. With some luck both spacecraft will soon celebrate their 50th launch day, before they will quietly sail on amidst the stars by next decade as a true testament to every engineer and operator on arguably humanity’s most significant achievement in space.
Thanks to [Mark Stevens] for the tip.
Continue reading “See Voyager’s 1990 ‘Solar System Family Portrait’ Debut”
Open Source Rover Gets An Update For Easier Building
Once upon a time, NASA-JPL put out a design for an open-source rocker-bogie rover. It was an impressive and capable thing, albeit a little expensive and difficult to build. Now, the open source community has dived in and refreshed the design, making it cheaper and more accessible than ever before.
Many parts of the original design have either become prohibitively expensive, gone out of stock, or been discontinued entirely. The new version, developed by the community that formed around the project, focuses on using off-the-shelf parts to bring costs down. Where the original design could cost as much as $3000 to build, the new model slashes that bill almost in half. It also eliminates any need for anything custom fabricated, with no machined or 3D printed parts required.
Other optimizations include cutting the rover’s head out from the basic model, as it’s not necessary for a great deal of applications. There is also better fluid and dust ingress protection, and improved serviceability. The entire rover model can also be loaded in OnShape for those desiring to inspect it or make their own modifications.
Parts lists are on GitHub for those desiring to build their own. Alternatively, check out the original design to learn more. Video after the break.
Continue reading “Open Source Rover Gets An Update For Easier Building”
