This Thermometer Rules!
A PCB ruler is a common promotional item, or design exercise. Usually they have some sample outlines and holes as an aid to PCB design, but sometimes they also incorporate some circuitry. [Clovis Fritzen] has given us an ingenious example, in the form of a PCB ruler with a built-in thermometer.
This maybe doesn’t have the fancy seven segment or OLED display you were expecting though, instead it’s an ATtiny85 with a lithium cell, the minimum of components, a thermistor for measurement, and a couple of LEDs that serve as the display. These parts are interesting, because they convey the numbers by flashing. One LED is for the tens and the other the units, so count the flashes and you have it.
We like this display for its simplicity, we can see the same idea could be used in many other places.On a PCB ruler, it certainly stands apart from the usual. It has got plenty of competition though.
Pocket Cheat Sheets For Electronics
What started as business cards for [Nerdonic]’s engineering clients unexpectedly expanded into a project in its own right. A CheatKard set consists of seven electronics cheat sheets made in the style of PCB rulers. Sized at 80 mm x 50 mm, they should fit in your business card holder or wallet regardless of the standard in your country. Alternatively, the set can be held together with a small ring in the top corner. The cards are made from fiberglass PCB stock, 0.6 mm thick with gold plating and matte black solder mask. The stackup goes like so:
  • Cover
  • Measurements
  • Schematic Symbols
  • Component Values
  • Footprints, SMD 1
  • Footprints, SMD 2
  • PCB Design
  • Laws and Theory
Even before shipping this electronics set, [Nerdonic] has already been asked to make sets of CheatKards for other fields, such as photography, chemistry, antenna design, mathematics, etc. While these aren’t as comprehensive as the Pocket Ref book from years gone by, we like a good cheat sheet. If you want to get a set, check out [Nerdonic]’s Kickstarter project which was funded within hours of going live, and see the short video clip below the break. He also makes a pledge to plant one tree in the Amazon rainforest for each set he sells.
Do you have any favorite cheat sheets or cheat sheet making techniques? Do you prefer your cheat sheets to be physical or stored on your computer? Share your comments down below.
Continue reading “Pocket Cheat Sheets For Electronics”
Hackaday Links Column Banner
Hackaday Links: Not A Creature Was Stirring, Except For A Trackball
Hey, did you know Hackaday is starting an Open Access, peer-reviewed journal? The Hackaday Journal of What You Don’t Know (HJWYDK) is looking for submissions detailing the tools, techniques, and skills that we don’t know, but should. Want to teach everyone how to make sand think? Write a paper and tell us about it! Send in your submissions here.
Have you noticed OSH Park updated their website?
The MSP430 line of microcontrollers are super cool, low power, and cheap. Occasionally, TI pumps out a few MSP430 dev boards and sells them for the rock-bottom price of $4.30. Here ya go, fam. This one is loaded up with the MSP430FR2433.
lol, Bitcoin this week.
Noisebridge, the San Francisco hackerspace and one of the first hackerspaces in the US, is now looking for a new place. Why, you may ask? Because San Francisco real estate. The current price per square foot is triple what their current lease provides. While we hope Noisebridge will find a new home, we’re really looking forward to the hipster restaurant that’s only open for brunch that will take its place.
The coolest soundcards, filled with DOS blips and bloops, were based on the OPL2 and OPL3 sound chips. If you want one of these things, you’re probably going to be digging up an old ISA SoundBlaster soundcard. The OPL2LPT is the classic sound card for computers that don’t have an easily-accessible ISA bus, like those cool vintage laptops. The 8-Bit Guy recently took a look at this at this neat piece of hardware, and apart from requiring a driver to work with any OPL2-compatible game, this thing actually works.
NVIDIA just did something amazing. They created a piece of hardware that everyone wants but isn’t used to turn electricity into heat and Bitcoin. This fantastic device, that is completely original and not at all derivative, is sold in the NVIDIA company store for under five dollars. Actually, the green logo silk/art on this PCB ruler is kinda cool, and I’d like to know how they did that. Also, and completely unrelated: does anyone want ten pounds of Digikey PCB rulers?
Hackaday Links: October 9, 2016
Atari is back! That’s what some dude says. There are no real details in that post, other than ‘Atari is Back!’
The ESP32 is coming, and it’s going to be awesome. Espressif has just released an Arduino core for the ESP32 WiFi chip. The digitalRead, digitalWrite, SPI, Serial, Wire, and WiFi “should” work. If you’re looking for ESP32 hardware, they’re infrequently available and frequently out of stock. Thankfully, stock levels won’t be the Raspberry Pi Zero all over again until someone figures out how to run an NES emulator on the ESP32.
Tiny, cheap ARM boards would make for great home servers if they had SATA or multiple network interfaces. Here’s a Kickstarter for a board with both. It’s based on an ARM A53 with multiple Ethernets, mini PCIe, enough RAM, and SATA. It’s a board for niche use cases, but those uses could be really cool.
You’re not cool or ‘with it’ until you have a PCB ruler. That’s what all the hip kids are doing. For wizards and dark mages out there, a simple PCB ruler isn’t enough. These rare beasts demand RF rulers. There’s some weird stuff on these rulers, like Archemedian spiral antennas and spark gaps. Black magic stuff, here.
Some dude with a camera in the woods did something. Primitive Technology, the best example of experimental archaeology you’ve ever seen, built a spear thrower. You can throw a ball faster with a lacrosse stick than you can with just your hands, and this is the idea behind this device, commonly referred to as an atlatl. You can hunt with an atlatl in some states, but I have yet to see a video of anyone taking down a deer with one of these.
Think we’re done spamming the Hackaday Superconference yet? YOU’RE WRONG. The Hackaday Superconference is the greatest hardware conference of all time until we do this whole thing again next year. Get your tickets, look at the incredible list of speakers, book your flights, and be in Pasadena November 5-6.
