[Jim’s] technique for turning a wireless doorbell into a custom ringtone player is so simple. He manages to get the entire thing done using only a screwdriver and wire clippers as tools. But if you’re looking to use this over the long-term we’d recommend soldering the connections rather than relying only on the twisted wires.
Above you can see all the components used in the project. The wireless doorbell unit is no different from most battery-operated units on the market today. Inside the Radio Shack box is a recording module that lets you play up to 20 seconds of audio. This is powered by the 9V battery on the right. [Jim] removes the speaker from the doorbell and clips off one of the wires that connected it to the board. This is reused as the ground connection for the recording module. The other speaker wire is connected to the ‘Play’ button on the module’s PCB. That’s it, just record your custom sound and pack everything back into the doorbell’s case. You can see the entire hack and hear a demonstration after the break.
Continue reading “Simple Hack Plays Any Sound As Your Door Chime”
