Steam power anything these days is pretty cool, but rarely have we ever seen such a complex build as this steam powered, remote controlled 1/16th scale tank.
[Ian] is an electronics design engineer whose hobbies include messing around with steam power. The Steam Turret Tank is based on a 1/16th scale Tamiya King Tiger die-cast model tank. It features a 3.5″ diameter marine boiler from MaccSteam, which is a fully equipped miniature version of a real boiler, complete with pressure gauges, safety valves, and a ceramic burner. It can produce pressures of up to 70PSI (max 120PSI), but for this project, [Ian] is limiting it to around 30PSI.
A small 2″ diameter fuel tank contains a propane mixture to fuel the boiler. Two Regner 40451 Piccolo steam engines make up the drive train, with mechanical linkages controlled by servos to engage the various features. The tank can go forward, backward, spin in place, and the turret can both rotate and adjust trajectory. It also has controllable headlights, and can even “fire” the turret.
Continue reading “A Remote Controlled, Fully Functional, Steam Powered Tank”
