If Dorothy from The Wizard of Oz were to wake up in 2017, with her magic Ruby Slippers on her feet, she’d probably believe she had woken up in a magical world. But modern folks will need a little more magic to impress them. Like Clicking your heels thrice to get home with these Uber ruby slippers. [Hannah Joshua] was tasked by her employer to build a quirky maker project. She got an idea when a friend complained about having trouble hailing a cab at the end of a hard day at work.
[Hannah] started with ruby colored slippers with a platform toe and high heels to allow space to stuff in all the magic dust, err, electronic bits. The initial plan was to use an Arduino with a GSM/GPS shield but that would have needed a separate SIM card and data plan for the shoes. Instead, she opted for the 1Sheeld which connects to a smart phone over Bluetooth. The 1Sheeld gets access to all of the smart phone’s sensors including the GPS as well as the data connection. The Arduino and 1Sheeld are put in a cavity carved out in the toe section. The 9 V battery goes inside another cavity in the heel, where an activation switch is also installed. Three LED’s indicate when the shoe is active, the cab request is accepted, and when the cab is on its way.
The code is basic since this one of her first Arduino projects, but it gets the job done. It sends an http request to Uber’s API to request a cab. The destination is hard-coded, so the slippers only allow you to get from your current location to whatever destination is programmed. The GitHub repository provides code, as well as some additional information on construction. [Hannah] has also added notes explaining some of the design choices and things to take care about if you plan to build one of these magic slippers.
We covered the 1Sheeld when it was introduced several years back, and if you get your hands on one, try building this Hand Waving Door Unlocker.
