Siamese Electric Motors
I’ve been meaning to post something about these for a while. Jim builds motors for EV hobbiests on the side – one of his cooler creations is the siamese electric motor. Some others have used belt drives to combine motors, but Jim actually builds the motors into a single unit. He built this set of 8 inch twins for the White Zombie drag racer.
I pumped Jim for more details, but he’s not done tweaking his next set of siamese motors. So, why is this even a hack? It’s a nice piece of machine work, but it gets interesting if you consider some stock specs. Most EV cars get 9″ motors – these are rated at 19hp or so. They take some monster hardware just to drive – high amperage, high voltage. Running a pair of 8hp motors can produce similar power with significant cost savings – everything gets cheaper. To generalize, you need a $1500 motor and $1000 controller just to get in the game. Not to mention that rebuildable forklift motors can be had for a song.
