We’ve all seen these on the side of the road and wondered how we could change the message. It turns out that it is actually pretty easy. There’s a keypad inside for programming that is often still set with a default password of “DOTS”. Even if the password has been changed, you can reset it right there pretty quickly. We shouldn’t even need to warn you that it is illegal to tamper with these, so unless there really are zombies ahead, you probably shouldn’t mess with it.
[via Neatorama]
