 [Peter]’s dad recently rekindled his love for Lionel trains and wanted a bell to keep the crossings safe for O gauge drivers and pedestrians. Using parts he had lying around and a doorbell from the hardware store, [Peter] concocted this DIY train crossing bell at his dad’s request.
The idea was to make the bell chime about once per second. To achieve this, [Peter] used a non-repeating electro-mechanical doorbell that emits a single note on continuous press. You could also roll your own bell with a spring-loaded solenoid and something bell-like for it to strike.
[Peter]’s three-stage design uses a full-wave bridge rectifier to convert the AC from the train transformer to DC. He drops it to 5V and sends it through a 555 and some resistors to set the frequency and duty cycle. His output section translates the voltage back up to match the input desired by the doorbell. [Peter] included a 1N4002 as a back EMF snubber to keep feedback from damaging the power MOSFET. Stick around for his demonstration video after the jump.
