Hackaday Links Column Banner
Hackaday Links: October 27, 2024
Problem solved? If the problem is supplying enough lithium to build batteries for all the electric vehicles that will be needed by 2030, then a new lithium deposit in Arkansas might be a resounding “Yes!” The discovery involves the Smackover Formation — and we’ll be honest here that half the reason we chose to feature this story was to be able to write “Smackover Formation” — which is a limestone aquifer covering a vast arc from the Rio Grande River in Texas through to the western tip of the Florida panhandle. Parts of the aquifer, including the bit that bulges up into southern Arkansas, bear a brine rich in lithium salts, far more so than any of the brines currently commercially exploited for lithium metal production elsewhere in the world. Given the measured concentration and estimated volume of brine in the formation, there could be between 5 million and 19 million tons of lithium in the formation; even at the lower end of the range, that’s enough to build nine times the number of EV batteries needed.
Continue reading “Hackaday Links: October 27, 2024”
