[Ben] finally got part 3 of his XBox 360 laptop how-to finished up. This is the final piece of the series. He spends it covering wiring up the ports, buttons, keyboard and final assembly. There are plenty of shops that handle special order laser cutting – so don’t begin to think that this sort of project is out of your class. If you’ve ever built a model car and can handle a soldering iron, you can definitely build one of these on your own.
I was just checking for this final piece this morning – but props to [Tony] for noticing it first.
