[Jkx] sent in his fonera SD card experiments. It looks similar to the wrt54g mod – bit banging the interface works, but it’ll be slow. I poked around [Jkx] site and found quite a few goodies. (We’ve noticed his He’s built a nice tube amp, but his push-pull tube amp looks very interesting. Oh, and his simple negative power supply could prove handy,
6 thoughts on “Fonera SD Card”
Leave a Reply to JoeCancel reply
Maybe you should point out that this is for the OpenWRT version of the hacked Fonera, not the user-friendly (ie gui’d) DD-WRT version.
i wouldn’t really call that “his” negative power supply, that’s taken right from the maxim datasheet.. but the site and other hacks are neat :)
This is sweet. :)
I lik ethe negative power supply
Also for OpenWRT there is a web-based GUI. It is available at http://x-wrt.org/
can i lean this hack
